Login For Surface Rt
ptciii
Hi, I'm new to surface and was hoping to get some advice. We have a good number of surfaceRT's that I need to update. My director gave me her surface to re-purpose and I've run into a block. On boot, her user name comes up as the only choice to login with. Is there a way to bypass her login and create a new login for me, or will I need to get her to login first before I can create my account? Thanks for the help. Paul
Get her login first then create an account for yourself
Yes, pretty much.  She will need to login and create another admin account for you to use.
You will need an admin account on each Surface RT you will be upgrading.
Or you can hard reset it and it will go back to the initial set up.
Sent from my Lumia Icon via Tapatalk
I think you'd have to reinstall the OS. If you have a recover USB drive that would work
Sent from my XT1254 using Tapatalk
