RMansfield Posted May 7, 2015 Share Posted May 7, 2015 Has anyone else come across anything similar? WiFi works as expected if I'm just using the Surface by itself. If I turn on my Bluetooth Logitech Ultrathin mouse, WiFi speeds drop drastically. Link to comment Share on other sites More sharing options...
schoondoggy Posted May 8, 2015 Share Posted May 8, 2015 Are you using the BlueTooth built in the Surface? Generally, BlueTooth is built into the Wifi chipset. I have had this issue with several laptops. Mainly if they have Broadcom chipsets. Go into Device Manger and see what Wifi chip is being used. Link to comment Share on other sites More sharing options...
schoondoggy Posted May 22, 2015 Share Posted May 22, 2015 Are you still having an issue? Link to comment Share on other sites More sharing options...
RMansfield Posted May 22, 2015 Author Share Posted May 22, 2015 I switched to the other channel on the mouse, and it's fine. Link to comment Share on other sites More sharing options...
