AllToga Posted November 10, 2010 Share Posted November 10, 2010 I am almost done with my data transfer after I had to rebuild my server. I'll have 7 TB of data, and ~14 pool drives. While I was copying the data over, I did not turn on duplication. Also, I had to use a temporary hard drive that I'll need to remove sometime soon. My question is which should I do first? Turn on duplication or remove the temporary hard drive? I'm leaning towards turning on duplication just increase the safety of my data. But on the other hand, I don't want to waste time duplicating the data on the temp drive, when I know I'm going to be removing it. I have enough space to turn on duplication with or without the temporary drive. Link to comment Share on other sites More sharing options...
ImTheTypeOfGuy Posted November 10, 2010 Share Posted November 10, 2010 With that many drives I don't think there is any one way that is better than the other If it was me, I would remove the drive and then turn on duplication. Link to comment Share on other sites More sharing options...
usacomp2k3 Posted November 11, 2010 Share Posted November 11, 2010 Both at the same time? Link to comment Share on other sites More sharing options...
AllToga Posted November 12, 2010 Author Share Posted November 12, 2010 I decided to protect the data, then remove the hard drive, so I turned on duplication for everything. >6 TB of data that needs to get copied. Fun stuff. Link to comment Share on other sites More sharing options...
