MrSteve007
Surface Pro 3, 512 Core I7 Thermal Images
MrSteve007
Here's the initial results my own testing of the Surface Pro 3, 512 w/ a core i7 with updated firmware, as of September 15th, 2014:
Testing, using Prime 95, prime number generator and CPU stressor. The computer had been running for 3 hours before the test began, so it was already at operating, idle temperature. It was also sitting in the dock. All temperatures are in F. Ambient room temperatures are at 70 degrees, 40% humidity.
@ 0 minutes, idle
CPU temperature: 120 degrees
CPU utilization: 4%
CPU speed: 0.85 GHz
Front maximum temperature: 98 degrees
Back maximum temperature: 95 degrees
@ 10 seconds, testing
CPU temperature: 190 degrees - limit reached
CPU utilization: 90%
CPU speed: 2.07 GHz (maximum observed speed, using Prime95)
@ 1 minute, testing
CPU temperature: 192 degrees - limit
CPU utilization: 75%
CPU speed: 1.70 GHz
Within the first minute of testing, the thermal limit had been reached and the fan kept the device running at the same temperature for the next 19 minutes, when the testing was halted. No instability or gross sluggishness was noticed during the testing. Some delay during photoshop actions and the machine was used to browse the Surface Geeks forums at the time. Interestingly, the highest case temperature was observed 10 minutes into the test, at 115 degrees on the backside. That temperature slowly decreased until the end of the test.
@ 20 minutes, end of test
CPU speed: 1.70 GHz
Front maximum temperature: 113 degrees
Back maximum temperature: 111 degrees
Post test: it took roughly 2-3 minutes for the system fans to bring the CPU & exterior temperatures back to the pre-test temperatures.
Initial conclusion: Considering I never saw the CPU speed drop below the chip's rated 1.70 GHz over the 20 minute CPU stress test, I would assume I could continue at that speed indefinitely. Further testing is needed to simultaneously stress the built in GPU and see the impact on CPU clock speed.
MrSteve007
And here are the promised thermal images:
Pre-test temperatures:
10710678_10154610150340296_3159243959302
10312530_10154610150325296_8047737073104
At the end of the test temperatures:
10670283_10154610150320296_6695227687878
10628528_10154610150485296_1398596226974
And as a point of reference, here's what the temperatures look like on an LED lit, multi-touch Dell P2714T 27-inch monitor:
10447769_10154610150510296_4550803842779
MrSteve007
While it probably deserves its own post/topic within the Surface Pro 2 forums, I decided to do a nearly identical thermographic test on my Surface Pro 2 (512 gig) with the early model core i5 4200U processor (1.60GHz). The only major difference in testing is that the Surface Pro 2 is connected to a USB 3.0 Dynadock, and outputting video to 4 external monitors, which raises the CPU utilization a bit.
Idle state:
1005022_10154616449025296_14623532986771
@ 0 minutes, idle
CPU utilization: 6%
CPU speed: 0.90 GHz
Front maximum temperature: 102 degrees (4 degrees hotter than Surface Pro 3)
Back maximum temperature: 106 degrees (11 degrees hotter than Surface Pro 3)
10712768_10154616462645296_6252192561933
10676132_10154616462640296_9168864335903
@ 10 minutes, end of test
CPU utilization: 80%
CPU speed: 1.82 GHz
Front maximum temperature: 109 degrees (2 degrees cooler than Surface Pro 3)
Back maximum temperature: 121 degrees (10 degrees hotter than Surface Pro 3)
10603793_10154616462655296_3615971427105
10612966_10154616462710296_3999735766269
Conclusion: the Surface Pro 2 does seem to be able to better maintain CPU speed while under high CPU loads (1.82 GHZ vs. 1.70 GHz). This resulted in notably higher case temperatures in the Surface Pro 2 vs. the Surface Pro 3. One area that overlooked in this testing scenario is the dramatically differently powered on-board GPU's that would likely result in improved graphic performance of the Surface Pro 3. Fan noise in the SP3 was more noticeable, and appeared to reach the thermal limit faster than the SP2 - but only by about 5 or 10 seconds.
In comparison, the Surface Pro 2 has had nearly a year's worth of firmware tweaks to optimize performance and thermal characteristics. I wouldn't be surprised if the Surface Pro 3 will see minor performance bumps from firmware optimizations - but that said, it does suffer on pure CPU to CPU GHz on CPU heavy tasks.
    • Guest
      By Guest
      Regardless of whether you have built your WHS or it arrived all in one piece there are certain steps you should take to get up and running with Windows Home Server.  This is not a step by step guide to installation.  They are all different.  This is more like Cliff Notes.  It's the stuff you need to know before you get started and some tips and tricks before, during, and after installation.  I will publish a check list or a cheat sheet list to go along with this podcast.
      News Items mentioned on the show
      The Home Server Show's new writers
      Home Build section - send yours in with photos
      Listen to the show for a freebie.
      Backing up your Mac with the new HP Mediasmart Server
      Feed Changes
      Thank you to all who submitted a fun quote for the last two shows.
      Dan Reynolds of Proxure (keepvault.com)
      George C.  Krom
      Diehard - homeservershow.com
      Phil Churchill MSWHS.com
      Jesse P.
      Jonas Svenson - Microsoft
      Andrew Edney UsingWindowsHomeServer.com
      Clive S.
      Donavon West - HomeServerHacks.com
      Ethan K.
      Jim C.
      Terry Walsh - WeGotServed.co.uk
      Ken Warren - Hejustpostsalot
      Alexander Kent kentdome.com
      Chris L. Lux - homeservershow.com
      Brian Binnerup - mymovies.dk
      Sam Wood - tentaclesoftware.com
      J. Ortiz - pixelconceptonline.com
      Follow the Podcast on Twitter!
      Don't forget to vote for the Home Server Show at Podcast Alley.
      My Blog at thedigitallifestyle.com
      [iTunes] Subscribe to the Podcast in iTunes(MP3).
      [Zune] Subscribe to the Podcast in the Zune Marketplace.
      [Mp3] Download the Podcast in MP3.
      [RSS] Add the Podcast feed to your RSS aggregator.
      [blog RSS] Add the Blog feed to your RSS aggregator.
    • Guest
      By Guest
      Today's show is a follow up to the Before you Build show.  It's a short show this week.
      News and Links mentioned in the podcast
      Microsoft's New Server, Foundation
      HP Upline is calling it quits.  Did we kill it?
      Windows Home Server February Update
      Add-In:  Update to WHS Outlook
      Norco SS-500 Hot Swap Backplane Review
      What should we do with a VIA A2000?
      Acer's EasyStore H340 Windows Home Server
      Windows Home Server Drive Balancer Utility
      Quick & Easy Windows Home Server OS Backup and Restore. | 4Hak3rs
      How to run HP Upline inside your Windows Home Server Console
      Leave me a voicemail with Skype! Click me to call HomeServerShow.com
    • AminRahdar
      By AminRahdar
      Hi Dears
      I have a surface pro 3, recently i 've installed windows 10 pro on my device.
      everything goes well since i upgraded it wrong with windows 10 enterprise that my windows didn't active
      so i clean install a windows 8.1 pro on my device.
      since i did this installation touch screen of my device did not work well
      sometimes works well but it does not respond to my touches usually
      i installed all surface drivers that exist in microsoft site
      i guess that this problem causes firmware does not installed
      please help me
      thanks.
    • ckqualls
      By ckqualls
      I'm in a choir which is stuck on paper, and we have to use 3 ring binders for uniformity.  I was hoping to find an insert that fits into a standard 3 ring binder that holds a Surface Pro 3. I've scanned the music into OneNote.
      Thanks,
      Kelly
    • Matt
      By Matt
      So the Surface Pro 3 was just announced, and at first I was so excited I was getting an anxiety attack. Until the whole N-Trig pen thing came to light. All of a sudden my elation turned to utter disappointment. But then I started thinking about my particular situation, and my past experiences with lesser pressure sensitivity, now I'm not so clear on how I feel about it.
      For starters, I primarily work on a Cintiq 24HD, which is amazing. It's currently paired with a MacBook Pro, but that laptop has some issues that the Surface line of products remedies very well.
      1. A Surface can be docked and undocked quickly and easily if you purchase the docking station. With the Macbook, it's a bit of a pain to have to unplug and re-plug half a dozen cables, every time I want to take it with me.
      2. A Surface can act very much like a digital sketchbook. It's small, light, easy to carry, decent battery life, and of course comes with a pressure sensitive pen. With the Macbook, I need to stuff it in a bag, with a separate Wacom tablet and pen. It's heavy,cumbersome, doesn't give me the pen on screen experience, and frankly, it makes me not want to bother with it; which is what led me to purchase a Galaxy Note 3, because it's easy to carry around (though it lacks in decent art apps outside of Sketchbook Pro)
      3. A Surface can unify some fragmentation in my digital art workflow. If I start a sketch on my Note 3, I'll then need to convert and transfer the file to my main computer for further work on it. I also have to deal with the fact that I can only work on a smaller canvas sizes with my Note 3, which usually means that I later have to scale up the sketch on my first layer before inking over it. There's also the fact that applications on each device are very different. I can't have the same features or custom brushes and settings on both.
      4. All of these say nothing of the simple fact that it's just nice when only having to deal with one operating system, one version of your favorite applications, and one place to keep all your files organized.
      Now, with the exception of the N-Trig decision, the Surface Pro 3 gets everything right, in my opinion. It's screen size and ratio is much better than the Pro 2, which seemed a little small in size and a lot awkward when in portrait. It's a great resolution, with (apparently) a beautiful screen. The stand is a dynamite change, particularly for artists. It's thinner, lighter, and more powerful too.
      Only the N-Trig pen is making me hesitant. However, with that in mind, I do recall a time when I worked with 256 levels of pressure sensitivity. My first graphic tablet was a Wacom Graphire 2. And just a few years ago I had a quick run with an Asus Eee Slate. Both of which I don't ever recall complaining about the levels of pressure sensitivity. It worked just fine for me.
      When I consider that I've worked with 256 levels before with little issue, plus the fact that most of my work will be done when my Surface is docked in my office and connected to my Cintiq, I start to question if the N-Trig thing is really all that bad. For all of the Surface Pro 3's benefits, is the N-Trig Pen really a deal-breaker?
      I'd like to ask anyone reading this what their opinion is. Have you ever used a N-Trig device before? Outside of pressure sensitivity differences, do you find it to be much of a different experience? If you were in my position, would you consider the Surface Pro 3?
      Thanks to everyone reading!
