Sd Card Questions
What is the maximum capacity you can fit in the sd card reader on a surface pro. Does it take a 128 or larger capacity card. When it was released 64gb was the max capacity available so all reviews state that as max what it can take.
Second question. Can you install programs on the sd card or only use it for storage.
Actually the only reason they said that 64 GB was the limit is because that largest SD card size available at the time. The practical limit is much higher. So if you've got about $150 to spend on a 128 GB micro SD, by all means pop it into your Surface Pro.
