math Posted July 28, 2014 Share Posted July 28, 2014 With "disable display scaling on High DPI" checked in the app properties, Flash CC 2014 is unusable on the Surface Pro 1. Attached is a screenshot, basically everything inaccessible with all windows. All content is pushed far to the right no matter how large you make the windows, it just goes further away. I can't find other complaints about this issue. Does anyone else even use Flash? Link to comment Share on other sites More sharing options...
SurfaceProArtist Posted July 28, 2014 Share Posted July 28, 2014 I haven't tried installing the CC 2014 programs on the older Surface Pros. So what happens if you untick the "disable display scaling on High DPI" box? Link to comment Share on other sites More sharing options...
math Posted July 28, 2014 Author Share Posted July 28, 2014 I haven't tried installing the CC 2014 programs on the older Surface Pros. So what happens if you untick the "disable display scaling on High DPI" box? Unchecking that box has the expected result of making the interface blurry and out of focus. So I think it is the "disable display scaling" option that is messing everything up. I don't think of this as a "fix". I haven't fully tested the program when it is all blurry, and I'm not sure I want to. Is there a way to get a program to display properly without "disable display scaling"? I wonder why it even does that by default! Link to comment Share on other sites More sharing options...
math Posted July 29, 2014 Author Share Posted July 29, 2014 Correction: Flash CC 2014 does not work on the surface pro under any circumstance! Whether you have display scaling on or off the program itself does not function. If you were to touch the pencil to the canvas for example a huge diagonal line suddenly draws across the screen as if it everything is offset too far to the right. I don't think its fair that Adobe Flash no longer works on the Surface Pro. I bought the device months ago and its already obsolete? Link to comment Share on other sites More sharing options...
math Posted July 29, 2014 Author Share Posted July 29, 2014 Adobe says they are aware of the issue. Link to comment Share on other sites More sharing options...
math Posted August 19, 2014 Author Share Posted August 19, 2014 I haven't tried installing the CC 2014 programs on the older Surface Pros. So what happens if you untick the "disable display scaling on High DPI" box? I have still not heard from Adobe about fixing this issue. As I said, they are aware that their software does not run on High DP! screens. But I am confused by this post: http://surfaceproartist.com/blog/2014/5/29/surface-pro-3-what-runs-what-doesnt Why would Flash run on the Surface Pro 3 and not the pro 1? I know that Photoshop has an experimental high DPI feature, but the other programs don't seem to run at all. I can't understand why I am the only one complaining about this issue when Adobe products don't even run on modern machines. Link to comment Share on other sites More sharing options...
SurfaceProArtist Posted August 20, 2014 Share Posted August 20, 2014 I'll double check my Flash findings to make sure that Flash actually runs on the Surface Pro 3. It could be as simple as a display driver issue between one model and the other. Link to comment Share on other sites More sharing options...
math Posted November 19, 2014 Author Share Posted November 19, 2014 I'll double check my Flash findings to make sure that Flash actually runs on the Surface Pro 3. It could be as simple as a display driver issue between one model and the other. People have the same complaints with the surface Pro 3. You have recently posted that Flash CC 2014 runs on the surface pro 3. How have you tested this? I would think that if you open flash and use the pencil or brush tool with the stylus, you'll find it does not function properly at all. Last thing I heard from Adobe was: "Please note that Flash CC 2014 is not compliant with HiDPI retina like displays yet on Windows" Link to comment Share on other sites More sharing options...
smashingtofu Posted December 13, 2014 Share Posted December 13, 2014 (edited) Recent Surface Pro 3 user here! I really love it... but of course:I have the same problem as well, I'm really concerned (as it is half the reason why I signed up for CC) but hoping Adobe resolves this problem. Unfortunately, they seem relatively quiet or indifferent about this problem...For the record I've tried much of what was advised: Disabling the HiDPI scaling. (Which crashes Flash as soon as I select Brush). Uninstall, remove via adobe's Creative Cloud Cleaner, reinstall.At the moment for me I can only use Flash if I uninstall Wintab with the downside of not being able to use pressure sensitivity at all...I suppose I'll have to start scouring the net and see if there are ways to increase the UI on CS6 flash for the time being. Edited December 13, 2014 by smashingtofu Link to comment Share on other sites More sharing options...
math Posted December 16, 2014 Author Share Posted December 16, 2014 (edited) Recent Surface Pro 3 user here! I really love it... but of course: I have the same problem as well, I'm really concerned (as it is half the reason why I signed up for CC) but hoping Adobe resolves this problem. Unfortunately, they seem relatively quiet or indifferent about this problem... For the record I've tried much of what was advised: Disabling the HiDPI scaling. (Which crashes Flash as soon as I select Brush). Uninstall, remove via adobe's Creative Cloud Cleaner, reinstall. At the moment for me I can only use Flash if I uninstall Wintab with the downside of not being able to use pressure sensitivity at all... I suppose I'll have to start scouring the net and see if there are ways to increase the UI on CS6 flash for the time being. Hey! If you want to use flash install Flash CC from the creative cloud. There is "Flash CC" and "Flash CC 2014" and they are two separate programs. "Flash CC" should work for you. "Flash CC 2014" doesn't work for anyone using a tablet. You shouldn't need to uninstall your driver! Edited December 16, 2014 by math 1 Link to comment Share on other sites More sharing options...
