Xpadder On Surface Pro
Eleddon
Hello, I have a question on the use of a program called Xpadder in the tablet Surface Pro 3. Xpadder is a program that serves for mapping the controls of the keyboard and the mouse in a control of console connected to the computer. My question is the following one:
Did you may mapping the controls of a gamepad(for example that of a PS3 or Xbox Usb), with the program Xpadder in a tablet with Windows 8? The question is that a portable computer or a tower, they have the keyboard and the mouse connected (in case of the portable one, ALWAYS), but the tablet does not have them, so I would like to know, first hand if the program Xpadder is capable of assigning the above mentioned keys though there does not exist a physical keyboard connected with the tablet. It would mean that the operating system Windows 8 of the tablet has the configuration of a keyboard "internalized" and that therefore for the tablet it is as if really you were pressing these keys with the control of the console.Or if it does not work, to connect a keyboard and a mouse, to form the Xpadder with the control and as soon as you have finished and guarded the configuration, to disconnect them and to continue using the control without problems. I wait to have explained well and without madman turns you, but he thinks about the benefits of mapear the controls with any control about the Surface Pro of Microsoft. Thank you very much;)
I am sorry that I cannot answer your question. I have not tried Xpadder on a Surface Pro, but please fix your post. I have no idea how you got 5 copies of the same text in there...
Maybe someone else can assist on the Xpadder question.
