Sign in to follow this
bulls96
Surface Pro 3 Accessories
Morgan
This time I used Tapatalk instead of the website.
Here's a picture of how I use the USB 3.0 hub. The blue cable is a USB 3.0 extension which allows me sit on the sofa while having the ethernet adapter, a USB 3.0 HDD and my smartphone to be plugged in. I've also used it to tranfer data between two smartphones.
The point of this post is to show that
1. the included four-inch USB 3.0 cable is insufficient, and
2. the hub works reliably with quite a load: an unpowered USB 3.0 HDD, the ethernet adapter, as well as a smartphone.
So you can buy it with confidence.
Sent from my Surface Pro 3 using Tapatalk
