Need Help Deciding...
NatalieRath
I am thinking of getting a Surface Pro 2.. but I have problem choosing 64 gb and 256 gb.
I want to know whether the 8 gb version really changes the performance a lot of not.
I am not really a tech expert so please help!
There's also a 128 GB version. If you don't plan to install a huge amount of software, that should be sufficient for most except power users.
Four GB is also plenty unless you plan to run memory intensive 64-bit applications like Photoshop with multiple images at high resolutions.
Take a look at this thread too:  http://www.surfacegeeks.net/forums/index.php?/topic/1268-i-want-a-surface-pro-2-which-one/
I would skip the 64.  If you need the extra RAM for your work then certainly the 256/8.  I got the 128 and it's my desktop and I couldn't be happier.  List a few of the apps you use and these guys will help you out.
Welcome to the forums.
Dave
