Zoom In And Out In Illustrator Default Stylus Sp2
reiaya
does anybody witj illustrator cs6 using the default stylus has the same problem as me, of the stylus never releasing? I zoom in, make an square and releas to see an specific part of my drawing... but for some reason my stylus nevé release, and so continues zoom in in and in and in.... until I select another tool, making my zoom tool rather unusable. someone help!
Sounds like pen tip might be sticking. You should test with another compatible pen. If you have a nearby Microsoft store, maybe they'll swap it out for you.
oh noo!! there are no such stores like that where I live, but i do have the warranty, so maybe... is a hardware problem? that would be.. wonderful if it is... Is it the same stylus as the surface pro 1?
Edited by reiaya
Yes, the pens are the same in the SP1 and 2. There are plenty of replacements you can try, including S-Pens designed for Samsung Galaxy Notes. The key is to see whether the repeated clicking is reproducible with a different pen.
agh...is really hard for me to get another stylus to test it without sneakily entering into a nest buy with my sp2 under my arm. But well Ill give it a try, because apparently I tried today outside on the windows explorer, tried to make a selection like in illustrator, of an square... and it worked! but sgaonndping the same in illustrator give the same issue, I hope is not my illustrator or should I download the updates?
Once you install the latest Wacom driver, let me know if you still have the issue with Illustrator. The fact that it works correctly in the desktop and not in the program leads me to think it's the driver. Until the most recent version of Illustrator CC, the program required Wintab support. That is what the Wacom drivers provide.
well it gets better just a little, but still i cant pick up the color with the stylus, just like it select it and then i need to clic it with my finger... and also O tested today a bamboo stylus from another guy andnthe same with the color palette and well the zoom, get better a little. just wondering can I map a right click within the radial menu? I cant right? also I tried to map the ctrl, and the alt, but well i guess i need to map a complete action right? light ctrl+z or the alt innpsd that is for picking colors
    • Joe_Miner
      By Joe_Miner
      By: JohnStutsman
      Figure 1 – The Calhoun Technologies HP 686745-002 “Refurbished” drive-cage in anti-static package with Dell 15” mini SAS cable resting on top with other drive-cages and HPE ProLiant ML10v2 Server
      A year ago when I was planning my move to Ohio I wanted to move my 5TB drives from my HPE ProLiant ML30 Gen9 to my HPE ProLiant ML10v2 in order to set up a “Mirror” backup of the files on my WHS2011 system using AllWay Sync on my ML10v2. The fastest way to make the move was to unplug the drive-cage in the ML30 Gen9 and plug it into the ML10v2! It fit perfectly and worked flawlessly. It also spoiled me!
      After settling in Ohio, finally, I wanted to return the ML30 Gen9’s drive-cage to its rightful place and I began searching for the best low-cost way to add a drive-cage to my ML10v2 that worked like the one in the ML30 Gen9 instead of the stock ML10v2 drive-cage. There’s a great discussion in the HSS Forums documenting forum members search for a similar drive-cage.
      Figure 2 – Pages 18 & 19 of HPE ProLiant ML30 Gen9 Server “Maintenance and Service Guide”; Part Number: 825545-001; December 2015; Edition 1; shows a spare part number 792351-001 for the Four-bay LFF Hot-plug drive backplane assembly which would include the a) Drive backplane and Drive cage – Part 792351-001 is the part I first looked for and found at Calhoun Technologies.
      After reading some great suggestions in the Forums I stumbled upon the 792351-001 in the parts number of the ML30 Gen9 manual and thought it should fit the bill and found a low-cost option at Calhoun Technologies for a 792351-001 “Refurbished”.
      Figure 3 – ML30Gen9 drive-cage (also 686745-002 footprint) compared to 792351-001 on bottom – the sharpie markings show how much wider the front of the 792351-001 frame is compared to the 686745-002 and why the front cover of the ML10v2 wouldn’t close on the 792351-001.
      The 792351-001 did work in my ML10v2 but I could not close the front cover on the ML10v2, so I kept looking while also trying to modify the 792351 with my Dremel. I could make it fit finally, but only after a lot of Dremel work and the end result didn’t look good.
      Figure 4 – Tag identifying the drive-cage assembly in ML30G9 as: HPE P/N 674790-002 Replace with spare HDD Cage, 4Lff, $u Gen8 Enhanced (686745-002) LITEON (Rev. 15-11-17. The 686745-002 that arrived was identified with a similar tag: HP P/N 674790-002 Replace with spare HDD Cage, 4LFF, 4U Gen8 Enhanced (686745-002) LITEON (Rev.A) 14-03-17.
      On the drive-cage out of the ML30 Gen9 I found the part number 686745-002 which I thought was the part number of the cage alone. (I was wrong about that!) I found it at Calhoun Technologies listed as HP 686745-002 “Refurbished” SPS-HDD cage 4LFF 4U Enhanced. Thinking that it was likely only the drive-cage without a backplane I ordered it since with the 792351-001 I had an extra backplane. I was wrong! The part number referred to the assembly of the drive-cage and backplane.
      As the following pictures will show the 686745-002 arrived with a backplane and it appears to be working flawlessly.
      Figure 5 – Front and Back of Calhoun Technologies HP 686745-002 “Refurbished” SPS-HDD cage 4LFF 4U Enhanced
      Figure 6 – Picture of backplanes L-R: ML30G9 Drive-Cage, 792351-001, and 686745-002
      Video of my installation of the 686745-002.
      Video 1 – Install Drive-Cage in HPE ProLiant ML10v2
      Figure 7 – Calhoun Technologies HP 686745-002 “Refurbished” SPS-HDD cage 4LFF 4U Enhanced installed in HPE ProLiant ML10v2
      Figure 8 – HPE ProLiant ML10v2 powered up and all 3.5” drives functioning in Calhoun Technologies HP 686745-002 “Refurbished” SPS-HDD cage 4LFF 4U Enhanced
      Thanks to the members of HSS Forum Thread: ML10v2 Drive-Cage for their many insights and suggestions and thanks to forum member ToyCeli22 for starting the thread.
      Figure 9 – 686745-002 drive-cage installed in ML10v2 on left and stock 674790-002 drive-cage back in the ML30Gen9 on right
      In the As-Built that follows I list how this ML10v2 is loaded. Be sure to check out more on this at ML10 and ML10v2 Forum and ML10v2 Drive Cage Forum Thread.
      As-Built (I named my Computer: SkyNet)
      HPE ProLiant ML10v2 Server Xeon E3-1220v3 32GB Unbuffered ECC RAM KVR16E11K4/32 OS: Windows 8.1 Pro B120i Logical Drive 01: OS drive – 1 x Corsair Force GT 240GB SSD in RAID0 on HP Dynamic Smart Array B120i RAID Controller – Port 1 (SATA III or 6GB/s) -- Icy Dock ExpressCage MB326SP-B Bay 1 B120i Logical Drive 02: Data drive – 1 x Samsung 256GB 840 Pro SSD in RAID0 on HP Dynamic Smart Array B120i RAID Controller – Port 2 (SATA III or 6GB/s) – Icy Dock ExpressCage MB326SP-B Bay 2 B120i Logical Drive 03: Data drive -- 4 x WD10JUCT 1TB 2.5” HDDs in RAID10 on HP Dynamic Smart Array B120i RAID Controller – Ports 3, 4, 5, & 6 (each SATA II or 3GB/s) – Icy Dock ExpressCage MB326SP-B Bays 3, 4, 5, & 6 P222 Logical Drive 01: Data drive – 4 x WD 5TB SE HDDs (WD5001F9YZ) in RAID5 on HP Dynamic Smart Array P222 RAID Controller Card – Ports 1, 2, 3, & 4 (each SATA III or 6GB/s) – mounted in Bays 1, 2, 3, & 4 of drive-cage 686745-002 “Refurbished” Calhoun Technologies Drive-cage 686745-002 “Refurbished” SPS-HDD cage 4LFF 4U Enhanced; Dell Poweredge T710 PG9KK Mini SAS SFF-8087 cable 15” (38cm) Icy Dock ExpressCage MB326SP-B (I used the existing SATA cable that had gone to the optical drive for bay 5 plus a Blue 18” SATA cable I had in stock from previous projects for Bay 6; StarTech Model SAS8087S450 19” (50cm) Serial Attached SCSI SAS Cable – SFF-8087 to 4x Latching SATA for Bays 1, 2, 3, & 4; I also used a Molex Y to two SATA Power Connectors) 60mm Fan mounted near the bottom front of ML10v2 to increase air flow for the P222 60mm Fan mounted in empty card slot to direct air flow directly on P222 heat sink (plus Molex to Fan splitter and Y Fan to 2 Fan connector cable)
       Please join us in the HSS Forums to discuss this and many other interesting topics.
      References:
      Check HSS Forum Post: http://homeservershow.com/forums/index.php?/topic/10796-ml10v2-drive-cage/
      Scsi4me.com 3.5” Drive Tray Caddy 4 HP ProLiant ML350e ML310e SL250s Gen8 Gen9 G9 651314-001 http://www.ebay.com/itm/231001449171
      Dell Poweredge T710 PG9KK Mini SAS SFF-8087 to SFF-8087 Cable 15” (38cm) https://www.amazon.com/Dell-Poweredge-PG9KK-SFF-8087-Cable/dp/B00NOEY3OS/ref=pd_sim_147_9?_encoding=UTF8&psc=1&refRID=1ZRF07DQQ5V1M36D045C
       HPE ProLiant ML30 Gen9 Server; Maintenance and Service Guide (Item 18 on pages 18-19 lists a Spare part number 792351-001 Four-bay LFF Hot-plug drive backplane assembly – this was where I initially got part number 792351-001 that I ordered from Calhoun Technologies – as stated earlier I found that it did work but I was unable to close the front cover of the ML10v2 or ML30G9 when that part was installed) http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c04905980-1.pdf
      Calhoun Technologies HP 686745-002 Refurbished http://www.calhountech.com/products/hp-686745-002-4-bay-sas-sata-lff-hot-plug-drv-cage.html
      Additional Fans in the HPE ProLiant ML10v2 http://homeservershow.com/additional-fans-in-the-hpe-proliant-ml10v2.html
      Installing Icy Dock 5.25” ExpressCage MB326SP-B http://homeservershow.com/installing-my-icy-dock-5-25-expresscage-mb326sp-b.html
      Other HSS ML10v2 Blog Postings: http://homeservershow.com/tag/ML10v2
      HSS HP ProLiant ML10v2 postings: http://homeservershow.com/forums/index.php?/forum/98-ml10-and-ml10v2/
      Check out my ML10v2 Play List:
      Unboxing Drive Caddies for my ML30 G9
    • Truxi
      By Truxi
      Hi there, newbie here.  Just got myself a Surface Pro 2, and I'm looking to put some software on it.  I bought a copy of Manga Studio Ex 4.0 awhile back, but it's on disk.  Is there a way for me to install it?  Preferably without having to buy another piece of hardware?
      I tried putting the disc contents on a jump drive, and that seemed to work, but after I put in my serial number, it told me it couldn't do things until I put the disc in.
      Thanks!
    • usacic
      By usacic
      I just updated my Surface RT to 8.1 and I am loving it. It is faster prettier and smoother. However, I don't seem to be able to get the photo app to display any pictures from my SD card. Any one else having this issue? any one with a temporary fix?
    • urik1488993270
      By urik1488993270
      On the Surface RT, you can't sync files from SkyDrive to Windows RT (unless they're OneNote notebooks, which can sync and be available offline, meaning that this is perfectly possible on RT — even in Windows Store apps). The only way to take files with you is to open them in Office; any changes you made get synced back when you reconnect, making a mockery of the idea that Windows RT can't sync to SkyDrive. It's just that Microsoft hasn't enabled it.
      See:  http://www.zdnet.com/windows-rts-achilles-heel-cloud-connections-7000009933/
      Has Windows 8.1 resolved this issue?
    • canta2009
      By canta2009
      Hello!
      I am a proud owner of a Surface RT. It is a great device and I can really do about 85% of what I need to do on a daily basis for my work as an academic. But - and perhaps with Surface RT there is always a but - there is the inevitable problem of essential programs you need for work and research.
      The three culprits are Evernote Desktop, Zotero Stand-Alone, and Calibre, a library management software. I can use Evernote for Windows 8 but I do not find the program as intuitive for managing immense amounts of data - it is perfectly fine for reading. And I find that the Evernote for Web is just slow on the device. I can use Zotero in Internet Explorer but it runs slowly - and is more compatible with Firefox. But Calibre - the one I rely on daily - is unavailable on RT. I can use the files but to actually manage them is a task. I have to use my work computer but I get tired of carrying it back and forth from work to home.
      The truth is that I am 1) Fairly happy with the device, 2) Not looking to upgrade to a more expensive device yet, and 3) Just need something for a few basic desktop tasks.
      My current plan is to get a companion device for my Surface RT that runs Windows 8.1. I could do one of two things -
      A) Purchase another inexpensive Windows tablet like a HP Stream 7 or Dell Venue Pro 8 and then use remote desktop when I need those programs. I like the simplicity of this option but working in India, I will have to order the tablet, have it shipped to my family, and then shipped to me. I estimate it may take 1 to 2 months.
      OR
      Purchase an inexpensive notebook like the Asus X207 or the HP Stream 11 and use that in tandem with the device. This seems like a bit much but I can get the device now in India.
      I do see this as a stop-gap measure until I can eventually get a system that combines both - I would love a Surface Pro 3 but can't quite justify the price with a low salary and student loans. And again, I think the Surface RT is perfect for most tasks.
      I wanted to ask the forum for any advice or thoughts. Does this sound a bit crazy? Has anyone tried Option A yet? Should I just simply throw in the towel and get a new device? Any advice would be deeply appreciated - thanks!
