Accessories Advice
pdm69
Hi looking for some advice on purchasing accessories that you recommend to use with the Surface Pro
Powered USB 3 hub
USB 3.0 to Gigabit Ethernet Network Adapter
Mini Display to HDMI Adapter (I have MS Adapter)
cheers!
I do not have a Surface Pro, but I have used these on ultrabooks. You may need to trim/angle the edge for the Surface Pro:
http://www.microcenter.com/product/369680/Mini_Display_Port_Male_to_HDMI_Female_Adapter
I have used this device on ultrabooks, there are reviews that it works with the Surface Pro:
http://www.amazon.com/StarTech-com-Gigabit-Ethernet-Network-Adapter/dp/B0095EFXMC
I would try this one as well:
http://plugable.com/products/usb3-e1000
I have not played with USB3.0 hubs much, but depending on what you are looking at connecting, I have found these docks to be very useful:
http://plugable.com/products/ud-3900
