Surface Rt Power Button Doesn't Work And I Can't Power On. Help.
Lacieelayn
So for the past month my power button has been a little sketchy. It wouldn't work after repeatedly being pressed. I would have to manually make it sleep and what not. Well my tablet hasn't been off until now and I can not turn it on. The battery is fine on the thing so I know that's not the case.
I have tried holding the power button down for 10 seconds and then turning it on as I would normally, also something to do with the volume button and the power button. I even tried holding the top right side of the power button down followed but 2 second intervals of pushing the power button down. I still have no luck. Any ideas or suggestions would be a big help. Thank you.
Are you thinking the button is faulty? If so none of this will work.  Reset is power button and volume down 10 seconds or more.  I don't know why but sometimes snapping in a keyboard helps.
