Surface 2 Requesting Bitlocker Key Almost Everytime I Reboot
usacic
I have been having lots of issues with my Surface 2, 90% of the time I reboot or boot my surface it requests my bitlocker key. Is anyone else having this issue? Did anyone manage to fix it?
Sorry, I haven't seen this issue using my Surface RT or my Nokia Lumia 2520. Both are running Windows RT 8.1
Good luck with your Surface 2. I've read about this issue. Can't recall if there is a fix yet or not.
Hopefully you're able to find a solution to your issue.  For what's it's worth, I've been asked for my bitlocker key once (happened about a month ago) on my Surface 2.  After finding the key and inputting the required code, I've never been asked again.  To tell you the truth, I don't understand why I was asked......
  • 3 weeks later...
    • Al_Borges
      By Al_Borges
      For sale , Microsoft Surface 3 tablet , 4 gigs memory, 128 gig storage
      good  used condition
      includes
      Urban Armor Gear scout case for surface 3
      Blue type cover for surface 3
      Surface 3 pen
      and charger/cable
      Asking $200 Plus actual shipping from Central Indiana, USA
      I love the tablet, but had to get an Ipad so I could facetime with my granddaughter !
    • andypdm
      By andypdm
      Hello everybody!
      I have a Surface Pro 4 i7 with 512GB which was very expensive! After a couple of months I have noticed that sometimes when I put it to sleep it won't wake up and I have to reset the whole thing. I love the device and use it a lot, and I twitted Microsoft and they contacted me and say that I have to replace it... I am OK with that but I live in UK and the service is from USA, they say they do not have my device and have to send me a refurbished one, on the other hand I can see the UK store has my model.
      My question is, what do you guys think of refurbished devices? Does it affect the performance? I am not too annoyed about the issue, I just do not put it to sleep anymore, but on the other hand it is annoying that a new and expensive item does not work properly. What would you guys do? I mostly use my Surface to draw with Illustrator and Photoshop...
      I would appreciate any short of advice and help!
      Thank you very much!
    • EON1488993291
      By EON1488993291
      Hello!
      I have a Surface RT (32 GB) and it only has 1.69 GB of space left on the HD. The thing is that I have almost nothing on it (just a few apps that I check and do NOT take a lot of space, and small files), so I don't know what is taking so much space. Does anyone knows where is all that memory going? I have not being able to find it (I have checked the size of the apps, delete the trash can, delete the internet history/cookies)...
      Also, I want to upgrade to Windows 8.1. These are the two ways that I have think of doing it, but I will like your opinion on which option is better (or if there is a better way):
      Plan 1: take the tablet to its original status (in PC settings > General > Remove everything and reinstall Windows), move the recovery files to a thumb drive (http://www.surfacegeeks.net/forums/index.php?/topic/192-surface-rt-how-to-free-up-4-gigabytes-of-storage-space-on-your-rt/), and do all updates to take it to Windows 8.1
      Plan 2: free some space by moving the recovery files to a thumb drive, make the upgrade to Windows 8.1, run a cleanup disk and defragment the drive
      Making a backup of the files in the tablet is easy b/c there is not much in it, but my main concerns for the process are: I am going to loose microsoft office? is it going to ask me for any key/license number (if I ever had one, I don't know where it is)? anything else that I am missing?
      Thanks!
      EON
    • phillyphotogmagee
      By phillyphotogmagee
      Ok, I have a feeling that this is a larger Windows 10 issue, but I am experiencing this with the Surface Pro 4, the ideal test hardware for anything
      Microsoft, right?
      Here is what we are trying to accomplish:
      Encyrypt our Surface Pro 4's (win 10 Pro) using Hardware-Based Encryption
      Why?
      A) Because it is faster for the SSD to perform the encryption rather than the process, since the SSD is already encrypted
      Better battery life (because the processor is not encrypting the volume)
      C) Performing software encryption on an already encrypted volume defeats many of the internal optimizations that SSDs have built in (leading to
      slower performance)
      How?
      We have taken stock Surface Pro 4s, straight from the box.  No applications or updates have been installed, we have not added to a domain.  The only
      modification we have made is to the Local Group Policy:
      Computer Configuration/Administrative Templates/Windows Components/Bitlocker Drive Encryption/Operating System Drives
      *Require additional authentication at startup (Enabled, default options)
      *Enable use of BitLocker Aauthentication requireing preboot keyboard input on slates (Enabled, default options)
      -Configure use of hardware-based encryption for operating system drives (Enabled, default options)
      What's Wrong:
      When I go to enable Bitlocker, I am being provided the prompt to encrypt Used Only, or Whole Drive.  From all of the literature I have read, this
      prompt indicates Software Encryption.  When I select Full Drive, it takes a while (over 10 minutes) to encrypt. Again, from my reading, Hardware
      Encryption should be immediate (as everything is already encrypted).
      Question:
      What am I missing?  Is there an issue with Hardware Encryption that I have not been able to identify on the Surface Pro 4?  Is this an OS issue? Are
      there any other troubleshooting steps that I can take a look at?  Again, these are stock units, fresh out of the box from Microsoft.
      Sources (these are just some, all have been verified using additional sources that repeat the information):
      Slower Performance- Hardware Accelerated BitLocker Encryption: Microsoft Windows 8 eDrive Investigated with Crucial M500
        http://www.anandtech.com/show/6891/hardware-accelerated-bitlocker-encryption-microsoft-windows-8-edrive-investigated-with-crucial-m500
      Steps to enable encryption- How to Enable BitLocker Hardware Encryption with SSDs
        https://helgeklein.com/blog/2015/01/how-to-enable-bitlocker-hardware-encryption-with-ssd/
      Technet on Why to Hardware Encrypt - Encrypted Hard Drive
        https://technet.microsoft.com/en-us/library/hh831627.aspx
      GP Settings to Enable Hardware Encryption - Enabling Hardware Acceleration of BitLocker
        http://blog.jflamb.com/enabling-hardware-acceleration-of-bitlocker/
    • GByOBRRLZG
      By GByOBRRLZG
      Hi, I'm thinking of getting a surface 2 for a familiy of 6.  Two parents and 4 young children.
      The children will need to access school websites that undoubtebly use flash and require a complex username, teacher's email, passcode / pin.
      What should I expect performance wise of a surface 2 with 6 people signed into it?
      Should I get the larger disk version of the surface because the whole family plans to use it?
      Is there an RT version of Last pass or a RT last pass like solution to remember all the passwords for the school sites?
      Thanks!
