Dell Venue 8 Pro Mini-Review
KC5ZRQ
Pros:
  • A quick processor
  • Good screen quality
  • Office Home & Student 2013 included
Cons:
  • Micro USB Power/Port combo
  • No USB 3.0
Other:
  • Miracast
For me personally, this is the right size for a tablet.  The updated Atom processor is powerful enough that this device can handle most desktop chores without a hitch.
The display, 1200 x 800, is the proper aspect ratio and resolution for the tablet to work its best.  Don’t let tablets with higher resolution displays draw you away from the Venue 8 Pro.  You need to see it to realize that it works great.  Text is especially crisp.  A hint: You might like to turn off the automatic screen brightness control using the control panel.  You will need to use the advanced settings link in the power options menu.
The most powerful office suite on the market is, without any doubt, Microsoft Office.  The Venue 8 Pro includes full versions of Word, Excel and PowerPoint.
The single greatest drawback of this device is that the power connection is also the only USB input, and since it is a micro USB connector, you must have an adapter to use it with any peripheral (not supplied).  The micro USB 2.0 port will not supply enough power for external hard drives.  The micro USB connector will break easily if you try to insert the power plug in backwards.  I did this.  The connector broke.  Dell was very good at providing to me a replacement tablet.
A full-sized USB port is definitely required on any tablet that runs Windows 8 or it will not meet the needs of the enterprise customer, which is Dell’s bread and butter.  If I had a USB 3.0 port I could use an external hard drive.  I could connect the tablet to a docking station, or any USB device, and simultaneously provide it with power.
The Venue is compatible with Miracast which can clone the tablet’s display, wirelessly, to a television or projector.  It should be great for PowerPoint presentations or playing NetFlix movies on your big screen.  It is not suitable for use as a second display.  There is too much lag which makes using the mouse difficult.
If you don’t need a real USB connector I would recommend this tablet.  I will be replacing my V8P as soon as I find a similar model with a full-sized USB connector.
Edited by KC5ZRQ
    • in2thepit
      By in2thepit
      Hi Folks,
      I am hoping that you can help with an issue I am having with my new HP Microserver Gen 10. Apologies if I am posting in the wrong place.
      The microserver CPU is constantly running at 100%. It occasionally dips but normally is maxed out. I have build the server from new using Samsung SSD drives in a Raid 1 configuration initially. I have also tried the following.
      1. Single SSD with windows 10 Pro
      2. Single SDD with Server 2016
      3. Raid 1 with Server 2016.
      4. Single SATA with Windows 10 pro.
      I have updated the firmware. I have downloaded all the latest drivers from HP's portal.
      I have tried to get support from HP but they are providing one excuse after another to explain why they cant support the server. Currently the server is about a month or so old.
      HP Support responses..
      1. Windows 10 isn't supported.. ( Despite having windows 10 drivers for this server on their portal)
      2. SSD drives are not supported
      3. SATA drives are not supported unless they have HP branding. ( The Gen 10 is being sold on Amazon with Western Digital drives included)
      We have tried killing of several services in Windows 10 as per articles that we have found online. We have set the Virtual Memory to refresh on reboot.
      None of the above have achieved anything.
      As a result of the CPU running constantly at 100% the system is unbearably slow and cant be used to run even the most basic of tasks.
      It looks like we have been left holding an expensive tin box.
      I have attached a screen dump showing the CPU utilization.
      Any help or advice at this point would be greatly appreciated.
      Kind Regards
      Carl
    • JackoUK
      By JackoUK
      Like the look of the new DELL XPS 15 2-in-1 with the new Intel CPU/AMD GPU hybrid design.
      Never really been sold on the idea of a laptop as a desktop replacement ...
      ... but this looks like a contender.
      https://www.cnet.com/products/dell-xps-15-2-in-1-2018/preview/
    • Joe_Miner
      By Joe_Miner
      By: JohnStutsman
      Figure 1 – The Calhoun Technologies HP 686745-002 “Refurbished” drive-cage in anti-static package with Dell 15” mini SAS cable resting on top with other drive-cages and HPE ProLiant ML10v2 Server
      A year ago when I was planning my move to Ohio I wanted to move my 5TB drives from my HPE ProLiant ML30 Gen9 to my HPE ProLiant ML10v2 in order to set up a “Mirror” backup of the files on my WHS2011 system using AllWay Sync on my ML10v2. The fastest way to make the move was to unplug the drive-cage in the ML30 Gen9 and plug it into the ML10v2! It fit perfectly and worked flawlessly. It also spoiled me!
      After settling in Ohio, finally, I wanted to return the ML30 Gen9’s drive-cage to its rightful place and I began searching for the best low-cost way to add a drive-cage to my ML10v2 that worked like the one in the ML30 Gen9 instead of the stock ML10v2 drive-cage. There’s a great discussion in the HSS Forums documenting forum members search for a similar drive-cage.
      Figure 2 – Pages 18 & 19 of HPE ProLiant ML30 Gen9 Server “Maintenance and Service Guide”; Part Number: 825545-001; December 2015; Edition 1; shows a spare part number 792351-001 for the Four-bay LFF Hot-plug drive backplane assembly which would include the a) Drive backplane and Drive cage – Part 792351-001 is the part I first looked for and found at Calhoun Technologies.
      After reading some great suggestions in the Forums I stumbled upon the 792351-001 in the parts number of the ML30 Gen9 manual and thought it should fit the bill and found a low-cost option at Calhoun Technologies for a 792351-001 “Refurbished”.
      Figure 3 – ML30Gen9 drive-cage (also 686745-002 footprint) compared to 792351-001 on bottom – the sharpie markings show how much wider the front of the 792351-001 frame is compared to the 686745-002 and why the front cover of the ML10v2 wouldn’t close on the 792351-001.
      The 792351-001 did work in my ML10v2 but I could not close the front cover on the ML10v2, so I kept looking while also trying to modify the 792351 with my Dremel. I could make it fit finally, but only after a lot of Dremel work and the end result didn’t look good.
      Figure 4 – Tag identifying the drive-cage assembly in ML30G9 as: HPE P/N 674790-002 Replace with spare HDD Cage, 4Lff, $u Gen8 Enhanced (686745-002) LITEON (Rev. 15-11-17. The 686745-002 that arrived was identified with a similar tag: HP P/N 674790-002 Replace with spare HDD Cage, 4LFF, 4U Gen8 Enhanced (686745-002) LITEON (Rev.A) 14-03-17.
      On the drive-cage out of the ML30 Gen9 I found the part number 686745-002 which I thought was the part number of the cage alone. (I was wrong about that!) I found it at Calhoun Technologies listed as HP 686745-002 “Refurbished” SPS-HDD cage 4LFF 4U Enhanced. Thinking that it was likely only the drive-cage without a backplane I ordered it since with the 792351-001 I had an extra backplane. I was wrong! The part number referred to the assembly of the drive-cage and backplane.
      As the following pictures will show the 686745-002 arrived with a backplane and it appears to be working flawlessly.
      Figure 5 – Front and Back of Calhoun Technologies HP 686745-002 “Refurbished” SPS-HDD cage 4LFF 4U Enhanced
      Figure 6 – Picture of backplanes L-R: ML30G9 Drive-Cage, 792351-001, and 686745-002
      Video of my installation of the 686745-002.
      Video 1 – Install Drive-Cage in HPE ProLiant ML10v2
      Figure 7 – Calhoun Technologies HP 686745-002 “Refurbished” SPS-HDD cage 4LFF 4U Enhanced installed in HPE ProLiant ML10v2
      Figure 8 – HPE ProLiant ML10v2 powered up and all 3.5” drives functioning in Calhoun Technologies HP 686745-002 “Refurbished” SPS-HDD cage 4LFF 4U Enhanced
      Thanks to the members of HSS Forum Thread: ML10v2 Drive-Cage for their many insights and suggestions and thanks to forum member ToyCeli22 for starting the thread.
      Figure 9 – 686745-002 drive-cage installed in ML10v2 on left and stock 674790-002 drive-cage back in the ML30Gen9 on right
      In the As-Built that follows I list how this ML10v2 is loaded. Be sure to check out more on this at ML10 and ML10v2 Forum and ML10v2 Drive Cage Forum Thread.
      As-Built (I named my Computer: SkyNet)
      HPE ProLiant ML10v2 Server Xeon E3-1220v3 32GB Unbuffered ECC RAM KVR16E11K4/32 OS: Windows 8.1 Pro B120i Logical Drive 01: OS drive – 1 x Corsair Force GT 240GB SSD in RAID0 on HP Dynamic Smart Array B120i RAID Controller – Port 1 (SATA III or 6GB/s) -- Icy Dock ExpressCage MB326SP-B Bay 1 B120i Logical Drive 02: Data drive – 1 x Samsung 256GB 840 Pro SSD in RAID0 on HP Dynamic Smart Array B120i RAID Controller – Port 2 (SATA III or 6GB/s) – Icy Dock ExpressCage MB326SP-B Bay 2 B120i Logical Drive 03: Data drive -- 4 x WD10JUCT 1TB 2.5” HDDs in RAID10 on HP Dynamic Smart Array B120i RAID Controller – Ports 3, 4, 5, & 6 (each SATA II or 3GB/s) – Icy Dock ExpressCage MB326SP-B Bays 3, 4, 5, & 6 P222 Logical Drive 01: Data drive – 4 x WD 5TB SE HDDs (WD5001F9YZ) in RAID5 on HP Dynamic Smart Array P222 RAID Controller Card – Ports 1, 2, 3, & 4 (each SATA III or 6GB/s) – mounted in Bays 1, 2, 3, & 4 of drive-cage 686745-002 “Refurbished” Calhoun Technologies Drive-cage 686745-002 “Refurbished” SPS-HDD cage 4LFF 4U Enhanced; Dell Poweredge T710 PG9KK Mini SAS SFF-8087 cable 15” (38cm) Icy Dock ExpressCage MB326SP-B (I used the existing SATA cable that had gone to the optical drive for bay 5 plus a Blue 18” SATA cable I had in stock from previous projects for Bay 6; StarTech Model SAS8087S450 19” (50cm) Serial Attached SCSI SAS Cable – SFF-8087 to 4x Latching SATA for Bays 1, 2, 3, & 4; I also used a Molex Y to two SATA Power Connectors) 60mm Fan mounted near the bottom front of ML10v2 to increase air flow for the P222 60mm Fan mounted in empty card slot to direct air flow directly on P222 heat sink (plus Molex to Fan splitter and Y Fan to 2 Fan connector cable)
       Please join us in the HSS Forums to discuss this and many other interesting topics.
      References:
      Check HSS Forum Post: http://homeservershow.com/forums/index.php?/topic/10796-ml10v2-drive-cage/
      Scsi4me.com 3.5” Drive Tray Caddy 4 HP ProLiant ML350e ML310e SL250s Gen8 Gen9 G9 651314-001 http://www.ebay.com/itm/231001449171
      Dell Poweredge T710 PG9KK Mini SAS SFF-8087 to SFF-8087 Cable 15” (38cm) https://www.amazon.com/Dell-Poweredge-PG9KK-SFF-8087-Cable/dp/B00NOEY3OS/ref=pd_sim_147_9?_encoding=UTF8&psc=1&refRID=1ZRF07DQQ5V1M36D045C
       HPE ProLiant ML30 Gen9 Server; Maintenance and Service Guide (Item 18 on pages 18-19 lists a Spare part number 792351-001 Four-bay LFF Hot-plug drive backplane assembly – this was where I initially got part number 792351-001 that I ordered from Calhoun Technologies – as stated earlier I found that it did work but I was unable to close the front cover of the ML10v2 or ML30G9 when that part was installed) http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c04905980-1.pdf
      Calhoun Technologies HP 686745-002 Refurbished http://www.calhountech.com/products/hp-686745-002-4-bay-sas-sata-lff-hot-plug-drv-cage.html
      Additional Fans in the HPE ProLiant ML10v2 http://homeservershow.com/additional-fans-in-the-hpe-proliant-ml10v2.html
      Installing Icy Dock 5.25” ExpressCage MB326SP-B http://homeservershow.com/installing-my-icy-dock-5-25-expresscage-mb326sp-b.html
      Other HSS ML10v2 Blog Postings: http://homeservershow.com/tag/ML10v2
      HSS HP ProLiant ML10v2 postings: http://homeservershow.com/forums/index.php?/forum/98-ml10-and-ml10v2/
      Check out my ML10v2 Play List:
      Unboxing Drive Caddies for my ML30 G9
    • Joe_Miner
      By Joe_Miner
      By: JohnStutsman
      Figure 1 – HPE ProLiant ML30 Gen9 on static mat ready for Windows 10 pro x64 install via iLO4
      Figure 2 – This shows my Samsung 840 Pro (This will be my OS drive) set up in a single drive RAID0 in the B140i using SSA
      After manually installing Windows Server 2016 easily on HPE’s ProLiant ML30 Gen9 I was anxious to see if an install of Window 10 Pro would be just as trouble free. It was!
      Besides having Hyper-V capabilities, Windows 10 Pro, is being looked on by many as the basis of a low cost Home Server as illustrated in “Building a Windows 10 Home Server – Anniversary Update Edition”. Check out HPE’s Operating System Support Matrices for insights on the many OS’s that the ML30 Gen9 supports. But, what will work goes beyond what’s officially supported by HPE in the “Matrices”. Windows 10 Pro is not listed in the Matrices but Windows Server 2016 is and Server 2016 shares much of the code with Windows 10 Pro as does Server 2012R2 shares with Windows 8.1 pro and Server 2012 shares with Windows 8. In order to manually load Windows 10 Pro I downloaded drivers for Server 2016. The simplest procedure, for me, is to use SPP to update all the ML30 Gen9 firmware first, then use the drivers for the B140i to load Windows 10 Pro, then after Windows 10 Pro is loaded and updated use HPSUM to load all the relevant drivers and software into Windows 10 Pro.
      Like Server 2016, Windows 10 Pro has its own generic drivers that will work with the ML30 Gen9’s NIC and Video so the B140i drivers is all that’s needed to get Windows 10 Pro onto the ML30 Gen9! HPSUM run (with Administrator Privileges) will load all of the missing HPE drivers I need in one step – including the NIC’s, Video, and SSA – just to name a few.
      Step-By-Step: Windows 10 Pro on HPE ProLiant ML30 Gen9
      I used iLO4 to remote into the ML30 Gen9 and began to install Windows 10 Pro x64 manually (i.e. without using IP) in the following general steps:
      Since I had just recently done steps 1-7 not long ago I skipped to 5 then did 7 through 16 below.
      Download Service Pack for ProLiant (SPP) from Hewlett Packard Enterprise Support Center – Drivers & Software – the current version is 2016.10.0 (24 Oct 2016) – check also threads about SPP at HSS Forum MS Gen8 Load the SPP ISO in “virtual drives” in remote desktop of iLO4 Boot the ML30 Gen9 – with no drives in the ML30 Gen9 in my case – and let SPP run automatically and update all firmware – See Figure 3 below. Shut down the ML30 Gen9 Next: I removed the Samsung 840 Pro 256GB that I had loaded Server 2016 on (giving me the flexibility to switch OS’s by switching SSD’s in the ML30 Gen9) and loaded another Samsung 840 Pro 256GB into drive 1 of the Icy Dock ToughArmor MB994SP-4SB-1 Go to the Hewlett Packard Enterprise Support Center – Drivers & Software – and download the file cp028631.exe that is the Dynamic Smart Array B140i Controller Driver for 64-bit Microsoft Windows Server 2012/2016 Editions (Since Windows 10 has the same core as Server 2016 I plan to use it for manual installation of Windows 10 64-bit Pro in the ML30 Gen9 – the HPE Drivers & Software site does not have Drivers & Software for non-server OS’s) – the current version is 62.12.0.64 (24 Oct 2016) Extract the files in cp028631.exe and load those into a file folder that I then attach/load in “virtual drives” of remote desktop of iLO4 (during Windows install this will be the folder I browse to so that Windows 10 can pull in the driver and see the Samsung 840 Pro ) Load the Windows 10 Pro x64 ISO in “virtual drives” of remote desktop of iLO4 Boot the ML30 Gen9 During boot go into IP (press F10) and select SSA (Smart Storage Administrator) In SSA I set up the Samsung 840 Pro as a single drive RAID0 to be used as my OS drive – See Figure 2 earlier. Exit SSA & IP and Restart the ML30 Gen9 Proceed with the normal Windows 10 Pro x64 install – During install Windows 10 will ask for location of drivers so it can see the drive(s) – in browse lead it to the location to the file folder of B140i driver(s) in the “virtual drives” C: -- if your OS drive had been previously formatted as MBR you will have to delete that so it can be formatted as GPT. See Video 1 below. After Windows 10 is installed and updated – reattach SPP ISO in remote desktop of iLO4 In the Windows desktop go to the SPP ISO in File Explorer and Execute the Batch file for HPSUM (i.e. execute: launch_hpsum.bat as Administrator) – I chose “Localhost Guided Update” – Automatic Mode After running HPSUM (and rebooting) the HPE software shown in Figure 4 below was installed. Enjoy!
      Figure 3 – After running SPP’s ISO the firmware of the ML30 Gen9 is up to date.
      Video 1 – Browsing to select the file folder with B14i S2016 drivers during install of Windows 10 Pro on HPE ProLiant ML30 Gen9
      Figure 4 – Software installed by HPSUM in Windows Server 2016
      Figure 5 – Temperatures in the ML30 Gen9 via iLO4. BIOS is set on optimal cooling and my single System Fan is running at 6% and the two 40mm fans on the MB994SP-4SB-1 are turned on.
      Figure 6 – System information showing Windows 10 Pro as the OS
      Figure 7 – Basic information showing Windows Server loaded onto my HPE ProLiant ML30 Gen9 running from a single SSD RAID0 in bay 1 of the Icy Dock ToughArmor MB994SP-4SB-1
      All in all Windows 10 Pro was easy to load onto the HPE ProLiant ML30 Gen9 providing a relatively cheaper platform (compared to Windows Server 2016) for a home lab for setting up and testing applications in Hyper-V for instance.
      In the As-Built that follows I list how this ML10v2 is loaded. Be sure to check out more on this at ML10 and ML10v2 Forum and Windows 10 Pro on HPE ProLiant ML30 Gen9 Forum Thread.
      As-Built (I named my Computer: Serenity)
      HPE ProLiant ML30 Gen9 (Product No. 830893) Xeon E3-1240v5 (SkyLake LGA 1151) 8GB ECC RAM (Expandable to 64GB) OS: Windows 10 Pro B140i Dynamic Smart Array: Ports 1-4: (4*3.5” Drive Tray Caddies for Main Drive-Cage Assembly Bays 1-4) B140i Dynamic Smart Array: Ports 5-6: Icy Dock MB994SP-4SB-1 in Top 5.25” half-height Bay; with/ 2*18” SATA III (6 Gb/s) cables attached to Bays 1 & 2 (Bays 3 & 4 are available for future); Molex to Molex & Fan Y-Connector Cable; Samsung 840 Pro 256GB in Bay 1;
      Please join us in the HomeServerShow Forums to discuss this and tell us what you are building at home.
      References:
      Check HSS Forum Post: Other HSS ML30 Blog Postings: http://homeservershow.com/tag/ML30
       HSS HP ProLiant ML30 Forum postings (In HSS Forum ML10 & ML10v2): http://homeservershow.com/forums/index.php?/forum/98-ml10-and-ml10v2/
      HP MicroServer Gen8 – Service Pack for ProLiant – 24th Oct 2016 http://homeservershow.com/forums/index.php?/topic/12034-hp-microserver-gen8-service-pack-for-proliant-24th-oct-2016/
       iLO Advanced License Keys http://homeservershow.com/forums/index.php?/topic/9511-ilo-advanced-license-keys-1850-2400/
       Icy Dock “ToughArmor” MB994SP-4SB-1 http://www.icydock.com/goods.php?id=142
       HPE ProLiant ML30 Gen9 Server QuickSpecs http://h20195.www2.hp.com/v2/GetDocument.aspx?docname=c04834998&doctype=quickspecs&doclang=EN_US&searchquery=&cc=us&lc=en
      HPE ProLiant ML30 Gen9 Server “Maintenance and Service Guide”; Part Number: 825545-002; November 2016; Edition: 2 => http://h20565.www2.hpe.com/hpsc/doc/public/display?sp4ts.oid=1008556812&docLocale=en_US&docId=emr_na-c04905980 Or go to => http://h20565.www2.hpe.com/portal/site/hpsc/public/psi/home/?sp4ts.oid=1008556812&ac.admitted=1489520211680.125225703.1851288163#manuals
       Check out my HPE ML30 Gen9 Play-List:
    • Joe_Miner
      By Joe_Miner
      By: JohnStutsman
      Figure 1 – Preparing to install new 64GB of RAM
      I upgrade the stock 8GB to 64GB of RAM in the HPE ProLiant ML30 Gen9 using 4 DIMMs (“Sticks”) of Kingston KVR21E15D8/16.
      Figure 2 – Kingston KVR21E15D8/16
      Figure 3 – 64GB RAM about to be installed in HPE ProLiant ML30 Gen9
      Figure 4 – HPE ProLiant ML30 Gen9 – System Board Components & Memory “Type” requirement from “QuickSpecs” – DIMMs removal & installation instructions from “Maintenance & Service Guide” (see links in References below)
      Figure 5 – HPE ProLiant ML30 Gen9 – Memory & DDR4 memory population guidelines from “QuickSpecs” (see links in References below)
      I upgraded to 64GB of RAM in my HPE ProLiant ML30 Gen9 using Kingston KVR21E15D8/16 from Newegg. The KVR21E15D8/16 was suggested by Schoondoggy on the forum thread RAM for ML30 Gen9.
      Video 1 – 64GB RAM in HPE ProLiant ML30 Gen9.
      Figure 6 – View of the four new DIMMs installed for 64GB of RAM. Time to replace the air baffle, tower bezel, and side panel then hook up the ML30 Gen9 and see if it works!
      Figure 7 – IT WORKS! Screen during first post showing 64GB RAM - for the first time!  Thank you Schoondoggy!!
      Figure 8 – System Summary Information showing 64GB RAM installed
      Figure 9 – System Information with Installed Physical Memory (64GB RAM) Highlighted
      Figure 10 – Task Manager showing 64GB of DDR4.
      Figure 11 – iLO4 System Information – Memory Information showing four 16GB DIMMs installed.  Status is "Good, In Use".
      Figure 12 – Temperatures appear well within range while system fan speed was a consistent 6% - BIOS set to Optimal Cooling (Note that the two 40mm fans in the Icy Dock ToughArmor MB994SP-4SB-1 were also running).
      Figure 13 – HPE ProLiant ML30 Gen9 running with 64GB RAM and using 30.1 Watts. Everything seems to be working well – time to think about adding more drives and turn on Hyper-V!!
      HPE ProLiant ML30 Gen9 (Product No. 830893) Xeon E3-1240v5 (SkyLake LGA 1151) 64GB ECC RAM – Kingston KVR21E15D8/16 OS: Windows 10 Pro B140i Dynamic Smart Array: Ports 1-4: (4*3.5” Drive Tray Caddies for Main Drive-Cage Assembly Bays 1-4) B140i Dynamic Smart Array: Ports 5-6: Icy Dock MB994SP-4SB-1 in Top 5.25” half-height Bay; with/ 2*18” SATA III (6 Gb/s) cables attached to Bays 1 & 2 (Bays 3 & 4 are available for future); Molex to Molex & Fan Y-Connector Cable; Samsung 840 Pro 256GB in Bay 1;
      Reference:
      RAM for ML30 Gen9 http://homeservershow.com/forums/index.php?/topic/14807-ram-for-ml30-gen9/
      ValueRAM Decoder https://www.kingston.com/us/memory/valueram/valueram_decoder
      ValueRAM KVR21E15D8/16 Specs Sheet http://www.kingston.com/dataSheets/KVR21E15D8_16.pdf
      HomeServerShow Forum for ML10’s & ML30’s http://homeservershow.com/forums/index.php?/forum/98-ml10-and-ml10v2/
      HPE ProLiant ML30 Gen9 Server Maintenance & Service Guide http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c04905980-1.pdf
