First WHS Build
motorcycle
You can also use a great utility from Microsoft that you can download for free and it work with any ISO. You can download the trial version ISO, install with you key number. It is very straight forward and will require less updates afterwards as it already has PP3 included.
1. Download ISO of trial
2. Download Utility for creating a bootable/installable USB disk from any ISO
3. Run the utility and make the USB install
4. Change you BIOS (if required) to boot from the USB stick
http://store.microsoft.com/help/iso-tool
You can download the trial version her
http://www.microsoft.com/downloads/en/details.aspx?displaylang=en&FamilyID=e3694b69-93f6-4267-b881-55ce0648c784
Thank you but I just spent the last 5 hours getting it installed. I kept getting an error toward the end of the install.
I finally did a google and got it the answer (log off as user to let the usb stick continue).
Now I am looking for a list of add-ins to install and get everything up and running.
