First WHS Build
motorcycle
Well all the parts and pieces are coming in on the brown truck.
I'm looking for and ideas, comments or words of wisdom before I put this
together over the weekend. It sure is nice to have this forum to read and get ideas
and guidance from. I listen to all the podcast's from BYOB and WHS.
Parts List
G.SKILL Ripjaws Series 4GB (2 x 2GB)
COOLER MASTER Silent Pro M600 RS-600
Intel Core i3-540
GIGABYTE GA-H55N-USB3
2- SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM SATA 3.0Gb
1- SAMSUNG Spinpoint F4 HD322GJ/U 320GB 7200 RPM
LIAN LI PC-Q08B Black Aluminum Mini-ITX Tower
The case just arrived, just waiting on the rest
Thanks Jack
Parts List
Intel Core i3-540
Thanks Jack
Wow, just looked up the case and it looks really nice. This looks like a very cool build. I might need to do one of these myself when Vail finally comes to general release. Please let us know how the build goes.
Thanks Stan
Wow, I am doing my very first build and will be using almost the exact same part list. I am going with the Zotac H55 MB because it has 6 sata ports to use in the 6 bays of the case. You can follow my build here:
http://homeservershow.com/forums/index.php?/topic/1178-first-pc-build-ever-vail/
I have all the parts except just waiting on the case. Will be starting over the holiday weekend and will try to post pictures and log all messes I get myself into. I'll follow this post to see how you're doing. Good luck.
mrossco turned me on to this for your HDDs
http://www.frozencpu.com/products/11324/cpa-417/Lian_Li_Quad_SATA_Cable_w_Latch_-_Right_Angle_to_Straight_-_Black_SATA-LT90-4.html
Edited by Neophyte
Guys good luck with you builds. I like that cable. I am a lian-li guy and I have never seen that one before. Let us know how it works out.
The server is built and up and running with Vail. I changed the mother board to a Zotac (6 sata ports) and changed out the cpu fan. I went with the Thermaltake Slim X3 Low Profile 36mm Height CPU Cooler CLP0534. It is quieter than the stock Intel and I am not getting the whine noise. I also put in a 250gb 2.5 drive as a system drive, that I had left over from an upgrade on my Zotac Blueray HTPC.
Does anyone know of a way to use my movies on the vail machine? Or maybe I should just reformat and go to the orginal home server software. I'm just not sure which way to go. I have a bunch of movies and tv series dvd's that I would like to rip to my server.
I appreciate the feedback. Thanks
Well the server is up and running with Vail. I have been reading the forums lately and decided to go with V1 software. The package I bought includes a oem preinstallation kit and the dvd etc. for Home Server .I do not have a dvd drive on the server so should I use a usb drive?
Not sure exactly what to do, so any suggestions would be helpful. Thanks guys
