Surface Pro 2 Question Please
israguard
Good morning,
I'm just about to purchase the Pro 2 256GB model.  I saw it and find it to be VERY cool. I am a big email (Exchange Server) user.  The rest is just surfing the web.  Cost wise this unit comes in at about 1/2 the price of a laptop with the same specs.. So its almost a no brainer.
My question is about a product called Magicjack.  I travel quite a bit and use the Magicjack which is a plug in USB gizzmo to make free LD calls.  In your opinion, will the Surface Pro handle this easilly ?
Thanks in advance.
Regards, Shawn
The Surface Pro has a full-size USB port so the device should plug right in.  Unfortunately I don't know anything about Magickjack so can't say how that will work but if you've used it on a Windows PC before, you should be okay.
