Other Storage Issues After Installing Gdr2
WaynetheITGuy
AT & T Lumia 920.
After installing the GDR2 update, I have over 13 gigs of space dedicated to other. I had not experienced this issue before the update.
Before the updates I was running about 11 updates.
Has anyone else experienced or heard of this?
Other than a hard reset does anyone know something else to try?
i discovered the problem Was an application. I have uninstalled and  reinstalled it. I found the offending using "Lumia storage check" . surprisengly the app is not located in the store. I installed it by using Bing  to search for the app.
Don't Know why the ability to see how much Storage apps are using  is not included in the OS!!
