zeeke Posted October 27, 2010 Share Posted October 27, 2010 Hi I recently had a 2TB Western drive die on me with a pretty hefty loss of data since i didn't have duplication on for my Movies. Thing is after this I have done checks on all my drives and my system drive is down to 0% Fitness SMART status. I need to replace it NOW. a couple of questions: 1: Is there a way to replace the system drive without having duplication on for all Shares without loosing data? 2: Is there a way to not have the system drive as part of the storage pool when I add a new drive 3: How do I go about replacing it if I have everything duplicated and use BDBB for the backups, can I just pull the drive and do a clean install? zeeke Link to comment Share on other sites More sharing options...
pcdoc Posted October 28, 2010 Share Posted October 28, 2010 Hi I recently had a 2TB Western drive die on me with a pretty hefty loss of data since i didn't have duplication on for my Movies. Thing is after this I have done checks on all my drives and my system drive is down to 0% Fitness SMART status. I need to replace it NOW. a couple of questions: 1: Is there a way to replace the system drive without having duplication on for all Shares without loosing data? 2: Is there a way to not have the system drive as part of the storage pool when I add a new drive 3: How do I go about replacing it if I have everything duplicated and use BDBB for the backups, can I just pull the drive and do a clean install? zeeke zeeke, 1. If you replace the system drive without duplication you "amy" loose data. 2. Not on Version 1 WHS 3. Pretty much as you described it. Duplicate, offload the backups to an external drive, put a new drive in, and do a server "Re-install" Link to comment Share on other sites More sharing options...
zeeke Posted October 28, 2010 Author Share Posted October 28, 2010 ok, thanks doc edit* I got BDBB working again, doing the backup now. Link to comment Share on other sites More sharing options...
