RobD
Citrix Receiver
simpkijd
I've been able to perform a little more testing using the Windows 8 Citrix Receiver app.  On my Windows 8 machine I see the exact same behavior as compared to my Surface 2 when trying to access the Primavera program when I choose to use the Citrix Receiver app.  I launch the ICS file and then the Citrix Receiver app launches, tries to connect, then crashes to a blank screen.  When I delete Windows 8 app and use the normal "Citrix Connection Manager" program, all works normally.....
To add insult to this problem, I'm able to log in and access the Primavera Data fine from my wife's Nexus 4 (using the android Citrix Receiver App)....  Tried to access the programs using Citrix Receiver for Windows Phone but I'm unable to even get Internet explorer to open get past the log in screen on the Host Springboard Website.   My log in credentials are fine but the website times out after try to log in.....
    • Al_Borges
      By Al_Borges
      For sale , Microsoft Surface 3 tablet , 4 gigs memory, 128 gig storage
      good  used condition
      includes
      Urban Armor Gear scout case for surface 3
      Blue type cover for surface 3
      Surface 3 pen
      and charger/cable
      Asking $200 Plus actual shipping from Central Indiana, USA
      I love the tablet, but had to get an Ipad so I could facetime with my granddaughter !
    • Al_Borges
      By Al_Borges
      the selection and quality of the windows 10 store apps   has taken a turn for the better in the last few months
      Software publishers have started to load in their win32 apps  in the Store
      The big one is  Itunes  of course.    I dont use Itunes per se but a program I use ( mediamonkey)  requires it to be installed to sync to Ipods and Iphones
      The big advantage of loading in Itunes this way  is that it leaves behind all the other crud  ( apple updater, Bonjour etc) and just does Itunes
      But there are several others that I have used and can recommend.  In some cases the author asks for a small fee for the program via the store.  but you can install on any  of devices hooked into your account and updates are handled thru the MS update process
      Paint.net  a solid paint/photoshop type program.  Very good program that I have used for many years.    This is the program that should have replaced MS Paint, rather than the POS  Paint 3D
      Libre Office   full featured office suite -  fork of the openoffice project  solid program  more like MS Office than the google office suite.  One of my daughters went to school using this and wrote her PHD thesis with it.
      Irfranview  Lightweight handy image viewer/editor.     I have used this program for over 20 years !!!!     If I need to just crop or lighten an image to paste into another document,  this is what I use.
      Inkscape   open source Vector drawing program -    similar to Adobe Illustrator  and visio     dont use this program often  but  since visio isnt part of the standard office 365 package,  a good program to have loaded up
      Autodesk CAD Mobile    Dont confuse this for a full featured CAD program , but for viewing and marking DWG files or creating simple CAD profiles,  this free program works fine
      Please feel free to pass along other useful items you found in the windows store
    • andypdm
      By andypdm
      Hello everybody!
      I have a Surface Pro 4 i7 with 512GB which was very expensive! After a couple of months I have noticed that sometimes when I put it to sleep it won't wake up and I have to reset the whole thing. I love the device and use it a lot, and I twitted Microsoft and they contacted me and say that I have to replace it... I am OK with that but I live in UK and the service is from USA, they say they do not have my device and have to send me a refurbished one, on the other hand I can see the UK store has my model.
      My question is, what do you guys think of refurbished devices? Does it affect the performance? I am not too annoyed about the issue, I just do not put it to sleep anymore, but on the other hand it is annoying that a new and expensive item does not work properly. What would you guys do? I mostly use my Surface to draw with Illustrator and Photoshop...
      I would appreciate any short of advice and help!
      Thank you very much!
    • EON1488993291
      By EON1488993291
      Hello!
      I have a Surface RT (32 GB) and it only has 1.69 GB of space left on the HD. The thing is that I have almost nothing on it (just a few apps that I check and do NOT take a lot of space, and small files), so I don't know what is taking so much space. Does anyone knows where is all that memory going? I have not being able to find it (I have checked the size of the apps, delete the trash can, delete the internet history/cookies)...
      Also, I want to upgrade to Windows 8.1. These are the two ways that I have think of doing it, but I will like your opinion on which option is better (or if there is a better way):
      Plan 1: take the tablet to its original status (in PC settings > General > Remove everything and reinstall Windows), move the recovery files to a thumb drive (http://www.surfacegeeks.net/forums/index.php?/topic/192-surface-rt-how-to-free-up-4-gigabytes-of-storage-space-on-your-rt/), and do all updates to take it to Windows 8.1
      Plan 2: free some space by moving the recovery files to a thumb drive, make the upgrade to Windows 8.1, run a cleanup disk and defragment the drive
      Making a backup of the files in the tablet is easy b/c there is not much in it, but my main concerns for the process are: I am going to loose microsoft office? is it going to ask me for any key/license number (if I ever had one, I don't know where it is)? anything else that I am missing?
      Thanks!
      EON
    • Dave
      By Dave
      Indianapolis, IN
      http://content.microsoftstore.com/store/detail-holiday/Indianapolis-IN
      Location
      Fashion Mall at Keystone
      8702 Keystone Crossing
      Indianapolis, IN 46240
      Phone: Coming Soon
      Where to find us
      This store is on the Lower Level of the Fashion Mall at Keystone, in front of Abercrombie & Fitch.
      I would like to start organizing a line party on release day. I'm not sure if it's possible to do a midnight release since it's in the middle of the mall. Hopefully we will have more info in the coming weeks.
