Surface Pro Wifi Issues
robteaboy
My surface pro seems to keep dropping its wifi connection.  I can usually fix it by running the troubleshooter on the desktop and I get a default gateway error. Anyone else having issues?
The router is a simultaneous dual band (hate to admit it) apple router.  Is there a way to tell which band the surface is actually using?
On my dual band, I had to set up separate SSID for each band. That is how I can tell which I am on.
You should be able to right click on the connection to get more information as well.
My SP drops its connection to my DLink DIR-628 occasionally. More specifically, it tells me the link has 'limited connectivity'. I simply tell it to disconnect and then connect and it seems to be fine again.
I just turned on my Pro and had no wifi networks found.  I rebooted at it worked.  Seems that there are still some minor kinks, but wifi problems have been pretty rare for me.
