Battery Warning?
RMansfield
Twice since I've had my Surface RT for less than two weeks, it's suddenly shut down without warning because the battery was drained. This has taken me by surprise both times because I had no warning.
Every other electronic device I own gives me a low battery warning, but the Surface RT does not.
Or am I missing something? Is there a setting that I could turn on so that I get a warning when the battery is low?
Ok, for the sake of anyone else who might have this same question, I figured out the solution to my issue. I raised the percentage of the low battery status to 10%.
Last night, when my battery got down this low, my Surface RT gave me a warning, and I was able to plug in before it shut down.
To make this post of value, why don't you tell us how you raised it.
Edited by ImTheTypeOfGuy
Maybe if you used a nicer tone in your post, someone would post the process.
1. Go to Control Panel in Desktop.
2. Select Power Options.
3. Select Change Plan Settings and then Change advanced power settings.
4. Select Battery: Low Battery Level.
5. Change to 10% or higher and hit Apply.
Thanks guys.
School dog, one should not assume tone in written text. If I was being curt you would have known.
