Is The Surface Pro Fine For Photo Editing?
truthsforme
truthsforme
Will the Intel i5 processor used in the surface be able to handle photo editing software like adobe PhotoShop and lightroom? Currently, I'm using an Acer with an AMD e-350 processor and 6gb ram to do photo editing. It takes a little patience because of the rather slow performance. Will the surface pro be considered a step up in terms of performance compared to my Acer? Rough estimate, how much of a performance increase should I expect (2x faster etc.)?
I would hope that they made the surface pro with photographers in mind, why else include a display port as oppose to an HDMI port, lol.
Thanks, regards
geekaccountant
Depends on the images and how you edit. For me, I wouldn't want to edit on a system with less than 8GB of ram. Heck, I have 16GB in my system and think it is not enough. Will it be good enough for some light editing, sure. But good enough for serious editing or large LR catalogs, no way. Plus the tiny screen is going to be an issue with editing large files.
Come to think of it, the video card will be a weak spot as well. PS CS6 takes advantage of the GPU to speed things up in some areas. Can't image the Surface Pro will come close to keeping up.
But, if you want to do some light editing and just use LR to catalog the images on a trip and publish to Facebook or Smugmug, I think the Surface Pro should be able to keep up, maybe. I will be getting one when they come out and I will let you know.
truthsforme
Thanks for your responses, everything is a little more clear now. But also, I thought more ram makes it easier to multitask, I had no idea it also makes doing 1 task easier. I guess I would be better off with one of those new asus ultrabooks that come with a discrete GPU. Strangely, on the anandtech.com futuremark benchmarks, the acer aspire s7 with i7 processor scored the highest for video and photo editing, even beating laptops with discrete GPUs.
geekaccountant
Depending on the level or editing you are doing Photoshop all by itself can eat up all 16GB of my ram, and actually way more. I have had Lightroom eat up a little over 8GB before. So yes, these programs really benefit from additional memory. Now if you are just doing light work (red eye, cropping, etc), then you can get away with much less memory.
truthsforme
I was listening to the surface geeks podcasts and my question came up! =D
Ok, so here is how I'm planning on using it and where I got the idea etc:
So first, I do photo editing using lightroom 4 and nik softwares (silver efex pro, color efex pro). I don't do over-the-top photo manipulation that really requires a GPU such as HDR. I work with files that are about 8mb each also.
My workflow is very simple: import to a temporary folder where I view the files that I want to edit. Separate the keepers from the non. Edit a few in lightroom then export the edited and keepers to a separate folder. Lastly, I transfer all the non keepers to an external hard drive. That way, space on my local storage won't ever run out.
I noticed that the surface pro comes equipped with a display port (as opposed to an hdmi port) which raised a question, why choose a display port over an hdmi? Then I started looking at some of the advantages of doing so. With a display port, you can connect the surface to high resolution monitors and take advantage of the full resolution, specifically up to 2560 x 1440, which is something that I'm currently planning on buying also. Then it hit me, is the surface pro also aimed at folks that can use the surface just like a Wacom tablet (sort of) to edit their photos? Initially, I thought this would've been a brilliant plan. Connect your surface to a higher resolution monitor while using your surface the same way someone would use a Wacom tablet to edit their work. The only factors getting in the way of that were the cpu and ram - which I now learned (thanks to geekaccountant) 4g ram might be too low for photo manipulation, which I also happen to agree. I wonder if there's any way of opening the thing and just replacing those 4gb ram card(s) with 2 8gb ram? A person can dream, lol.
I'm just going to appoint GeekAccountant as mod of this thread! His JPEG2Raw podcast qualifies him for that! Glad you heard it on the podcast. Thanks for listening and posting here.
geekaccountant
First point, you should almost always be shooting in RAW, especially since LR4 is so cheap these days that anyone wanting to get into photography beyond a point-n-shoot should own it.
Sounds like you are doing more light editing and the Surface Pro might be able to handle that, although I would like to know how much ram it will be running. You may be better off just putting Lightroom on it and save the heavy PS work for when you get back to your main editing setup. Also, keep the LR catalogs small on the Surface and that should help a bit.
Not sure about it acting as a Wacom tablet, but it would be interesting to try with a stylist.
I think until we actually have the Surface Pro, it's going to be hard to really determine what it can do and where it's limitations are. But I think for light LR work while in the field it should be able to handle it. Heck, it might be a good solution while in the field to load the images into a LR catalog and tag them with their keywords. Then when you get home, load them onto your main setup. Although if you shoot as much as I do, storage space on the Surface may be an issue.
    • Dewain27
      By Dewain27
      So, you went out and bought your Surface Pro or RT and you brought it home and thought this is awesome how small these are... Then you walk over to put it in your laptop bag and you are like "WOW this won't work!"  So, I jumped out looking for something that did not eat my Surface like a tiny dog biscuit to a great dane.
      So, I found the solution that I was looking for...
      Yes boys and girls it is a perfectly sized laptop bag for the Surface RT / Pro.  It is good to note that this thing not only perfectly fits the surface, but all of the other items you might want to bring.  Tons of pockets and zippers and such.
      Oh and did I mention that I love the fact that this thing has an awesome orange interior that gives it a little character.  If you like it comes in black and orange as well.
      The material is a smooth nylon-like material keeping it from having issues with getting a little wet and stain resistant.  I absolutely love this thing.  I would give some cons, but I can't find anything wrong with it.
      Here is the link to allow you to go there now and buy this immediately.  I have had mine for months and I have to say there is nothing else out there that compares... (that I have seen)
      http://www.amazon.com/CaseCrown-Horizontal-Messenger-Microsoft-Surface/dp/B009RV2BD2/ref=sr_1_1?ie=UTF8&qid=1363393738&sr=8-1&keywords=surface+bag
      Happy shopping....
      Oh... here is the link for it in black
      http://www.amazon.com/CaseCrown-Horizontal-Messenger-Microsoft-Surface/dp/B009RV2EOI/ref=pd_cp_pc_0
    • Loxodrome
      By Loxodrome
      Well, it was time to say goodbye to my Dell Inspiron mini 1012.  Over the years, I had upgraded the
      RAM from 1 GB to 2GB, Swapped out the spinning disk drive for solid state, and migrated the operating system from Windows 7 Starter, to Windows 7, Windows 8, and now to 8.1 beta.
      I had used the mini for a travel computer, to take to the coffee shop, and use in the kitchen (yes, I am that guy who uses a computer in the kitchen).  For home use, I also have a Desktop Tower running Windows 8, 8 GB ram, 1 TB hard drive, dual monitors, etc…
      So, I bought a Surface Pro 128 GB with type cover.  And I Love it!
      It has lightning fast start up, quick response, runs all the spreadsheets documents and presentations that I throw at it, and I even have Photoshop and Lightroom running on the Pro.  But I miss my dual monitors.
      I started looking for a solution, and found the Targus USB 3.0 Dual Video Docking Station (from
      amazon).  It connects via the USB port on the Surface Pro, supports dual monitors, Audio in and out, USB3.0 (x2), USB2.0 (x4), and Gigabit Ethernet.  So I ordered one, hoping that it would allow my Pro to push the video to my dual monitors.
      And…  It works better than I could have expected.
      I have the Surface Pro on my desk, with no cover. I hook up the Targus docking stating via the USB port, and plug in the power.  My dual monitors, Keyboard, mouse, external hard drive, desktop speakers, and yes, my Zune HD are all connected to the docking station.  I get my full keyboard and mouse, dual monitors, stunning sound quality, touch, swipe and gestures on the Pro screen.  And plenty of screen
      real estate to run my applications.
      The only tricky part of the setup is balancing the dpi settings between the Surface Pro screen, and the monitors.  The Pro screen is 1600x900 in a 10 inch diagonal screen, and the monitors are 1680x1050 in a 20 inch diagonal screen.  To find this setting, search for “dpi” from the Metro screen, the select the “Make test and other items larger or smaller” setting.
      The Surface Pro is normally set to Larger - 150%.  But for this setup, I changed the setting to
      Smaller -100%.
      With this setting, the icons, menus, and ribbons on the dual monitors are normal size.  The text
      on the Pro screen is a bit small, but still functional.
      Overall, I am VERY pleased with this set up.  In fact, it works so well, that I tore out the desktop tower, and moved it to the kids playroom for their homework, and gaming computer.
      I can’t wait to get 8.1 on here so I can take advantage of the new features.
    • Loxodrome
      By Loxodrome
      Well, I have a Surface Pro (yes, the origional) and I upgraded to Windows 10.
      Ever since I went to 10, The Surface wont stay asleep.  I put it to sleep, and close the cover, and throw it in my bag,  And the damn thing is burning hot when I get home.
      Also in general, My Surface Pro just runs HOT, has a much shorter battery life, and seems to be having bower management issues........
      Anyone else running old hardware like me?  And are you seeing issues with Windows 10 too??
      -Jon
    • jez77
      By jez77
      I personally feel after using my Surface for over two weeks that this product is ahead of its time.
      Just like Xbox was ahead of its time, when Nintendo and Sony dominated the gaming world and all gamers were like Microsoft can't just buy their way into the gaming industry with a powerful PC.
      And they did...
      They introduced Xbox Live and had an Ethernet port in the device way before anyone even considered online gaming with a console. High speed internet was just rolling out and then they charged you 50 dollars to play online. They had something there and bought into it and now look at where they are. Now the features that Microsoft created and supported, which people and reviewers then called crazy, expensive, niche have become industry standards for gaming.
      Similar to how games were becoming more multiplayer focused such as Goldeneye, WCW/NWO, sports games, Mario kart, super smash brothers, when Microsoft brought the idea of playing online. That niche market of multiplayer, at the time, became the driving force of the gaming industry is today with COD, Halo etc.
      Now the Surface...why would people want power or productivity in a tablet? Ask the millions of people who bought Apple office suite for Ipad, photoshop app, IPhoto, IMovie all for Ipad. The Surface is where the (at least) 10 in plus screen tablet industry is going. The current Ipad market is all going to the 7 plus inch screen format while the 10 in screen is going to be for productivity. I feel this is a great time to enter as now the focus shifting away from 10in screen form and going to 7in screen form, allowing for the 10in screen to be for productivity and the 7in to be for consumption and games. Similar to the niche market that wants productivity, a keyboard, a full OS, speed, flexibility in the tablet form factor. This is where 10 in plus screen market is going to... productivity, business, home personnel use etc.
       A few other examples...
      Dare I mention Zune and it subscription based model.. now we have Spotify, Rdio, etc. Time will show that a merge of a laptop and tablet is what everyone wants and needs. The Surface with get thinner, faster and maintain a longer battery life through the iterations to come.
      Microsoft is not perfect  but I trusted them with Xbox and their support for the software, and innovations lead me to believe that the Surface will follow suite as we are just scratching the surface (pun intended) of Microsoft vision of a unified ecosystem.
      Now trust me Surface, Windows 8 and the Next Xbox are all going to integrate together, the tools and devices have been planted. I bet the Windows 8 store and Xbox store are going to be similar, if not based on the same architecture.
      RANT BEGIN ( First I am sick of all these doomsday articles of Windows 8 is in dying and Surface is cool but its not selling as much as Microsoft wants. First Windows 8 is an operating system it is not an expansion pack to WOW. The adoption rate will increase as people by PCs for school, home etc. Just because a new OS comes out people do not throw their PC is the garbage or run out to upgrade an old PC (especially when it is not touch screen). The 1st IPAD was a big IPOD touch with a handful of apps such as Netflix, 4 plus generation and minor upgrades later it is a platform.
      On a side note I think Apple is in trouble as the magic that they had has gone with the late Steve Jobs, everything since has been pathetic tweaks (I think the punch everyone's been drink is getting a bit sour). I think Microsoft beat Apple to the punch of combining a touch and productive operating system. As Apple has been wasting incremental upgrades trying to make OSX into iOS with the gestures and such, Microsoft went all in with an operating system that can function in both environments, as when as ARM and mobile processors.
      I am sorry for my Apple rant but I am fed up with the public notion that everything Apple does is revolutionary. Some of it is, such as the 1st iphone, app ecosystem and 1st and 2nd gen Ipads. Apple will follow suite with a "productivity IPAD" Look how long it took them to release a 128GB (with flash not SSD memory) for A NICE $799. Not expensive though, but a 899 or 999 for full PC in the form of a tablet.. too expensive. Total double standard and not the same type of device so stop comparing .. "the verge, engadget.. etc"
      Today I downloaded a file from the internet, sent it to my home networked hard drive for backup, sent it wirelessly to my Canon/Brother (any) printer to print (oh not before hand writing a message on the photo), then dragged the file to my attached USB thumb drive to print at Target. I also plan to use the photo to write up Thank You and print them using a Avery printing template... all on my couch with a tablet.
      Just think how you would (with Apps.. and cost) or if you could do this with an Ipad. This is why the Surface is in a different league.) END RANT
      Well there is my rant, I will have more as I continue to read the internet, follow my tech news and use this wonderful tablet/PC from the future.
      Thanks for reading if you made it this far!!
      Great show SurfaceGeeks, I think you guys do a wonderful job sharing your opinions, advice and knowledge to all us Surface fans out there. Keep up the great work. And I love your tales from the Microsoft Store.. that should be a segment. Ha!
    • Dewain27
      By Dewain27
      So, I do DJing and lighting.  I was worried if I could really run an entire show with Surface.  I have to say it went well.  I ran all the music from my RT and all the lighting software (Nicolaudie Sunlite Sudio 2).  I found that the Surface Pro had no issues running all the scenes and controlling the lights for a 4 hour concert.  I ran all the music pre and post using the Xbox music app with a Xbox music pass.  I am pretty confident that I could probably run it all from just the Pro, but wanted to ensure that I had more than I needed for the event.
      I did run another event this weekend as well that was a full DJ event using my Smithson Martin DVS.  I did this on my Asus Zenbook Touch.  I was able to run both the Xbox Music app along with Sunlite for a 3 hour DJ event and even take requests adding to the playlist with no issues what so ever... It was pretty awesome.  Seeing that I could leverage Windows 8 to flip between music and lighting control with no delays.  I had numerous people ask me how I was doing all of it as you can see the screen from the audience when using the DVS.  It gives a great effect for those that haven't seen one.  I found this when I was working TechEd in 2012 and talked to the DJ to find out what the thing was that they were using on the stage.  Its expensive, but if you can afford one for mobile DJs it really makes the difference.  If you can't do the DVS, then try a touch screen and Emulator Pro.  I am going to test this with the Surface Pro, but don't see why it wouldn't work.  I can't imagine that the RT will allow the drivers to work though.
