Stylus Input
Sbfulmer
Hey guys,
I have ordered my surface and should be getting it in a few days! I am in college so will be using the Surface to take notes with quite often. Does anybody recommend a certain brand/type of stylus to use? Also, I have heard you can use a stylus in OneNote (which would be awesome!) is this true? Or does anyone recommend another note taking app?
Thanks!
I've been using the Adonit pro and it is working quite well. The only down side is that you can't rest your hand on the tablet while using the stylus, but I've pretty much got this mastered.
The Adonit makes a great deal of difference over the mushy rubber tips. I think it's worth the $30.
  • Like 2
