Good (Technical) Surface Links
scoobyx
I ran across a really cool blog written by a MS developer. Obviously, he's using/embraced the Surface tablet. He has a couple of really good nuggets that I thought were worth sharing.
Make the desktop more touch-friendly
I have done this - and while it flies in the face of the way I normally work (max resolution across the board - I *LOVE* screen resolution), I have to admit that it's really solid on the Surface.
http://www.daveamenta.com/2012-11/make-the-desktop-more-touch-friendly-on-surface-rt-windows-rt/
Run remote apps on the Surface
I am in the process of building out a new Server 2012 installation. Hopefully I will have some hands-on experience with this by the end of this upcoming weekend. Anyhow, I would say going through this process certainly isn't for everyone, but if you're technically inclined, it could be right up your alley.
http://www.daveamenta.com/2012-11/using-remoteapps-on-surface-rt-windows-rt/
Would it be worthwhile making a sticky post that the community could use to aggregate these kinds of links?
    • Al_Borges
      By Al_Borges
      For sale , Microsoft Surface 3 tablet , 4 gigs memory, 128 gig storage
      good  used condition
      includes
      Urban Armor Gear scout case for surface 3
      Blue type cover for surface 3
      Surface 3 pen
      and charger/cable
      Asking $200 Plus actual shipping from Central Indiana, USA
      I love the tablet, but had to get an Ipad so I could facetime with my granddaughter !
    • andypdm
      By andypdm
      Hello everybody!
      I have a Surface Pro 4 i7 with 512GB which was very expensive! After a couple of months I have noticed that sometimes when I put it to sleep it won't wake up and I have to reset the whole thing. I love the device and use it a lot, and I twitted Microsoft and they contacted me and say that I have to replace it... I am OK with that but I live in UK and the service is from USA, they say they do not have my device and have to send me a refurbished one, on the other hand I can see the UK store has my model.
      My question is, what do you guys think of refurbished devices? Does it affect the performance? I am not too annoyed about the issue, I just do not put it to sleep anymore, but on the other hand it is annoying that a new and expensive item does not work properly. What would you guys do? I mostly use my Surface to draw with Illustrator and Photoshop...
      I would appreciate any short of advice and help!
      Thank you very much!
    • EON1488993291
      By EON1488993291
      Hello!
      I have a Surface RT (32 GB) and it only has 1.69 GB of space left on the HD. The thing is that I have almost nothing on it (just a few apps that I check and do NOT take a lot of space, and small files), so I don't know what is taking so much space. Does anyone knows where is all that memory going? I have not being able to find it (I have checked the size of the apps, delete the trash can, delete the internet history/cookies)...
      Also, I want to upgrade to Windows 8.1. These are the two ways that I have think of doing it, but I will like your opinion on which option is better (or if there is a better way):
      Plan 1: take the tablet to its original status (in PC settings > General > Remove everything and reinstall Windows), move the recovery files to a thumb drive (http://www.surfacegeeks.net/forums/index.php?/topic/192-surface-rt-how-to-free-up-4-gigabytes-of-storage-space-on-your-rt/), and do all updates to take it to Windows 8.1
      Plan 2: free some space by moving the recovery files to a thumb drive, make the upgrade to Windows 8.1, run a cleanup disk and defragment the drive
      Making a backup of the files in the tablet is easy b/c there is not much in it, but my main concerns for the process are: I am going to loose microsoft office? is it going to ask me for any key/license number (if I ever had one, I don't know where it is)? anything else that I am missing?
      Thanks!
      EON
    • olivermills6
      By olivermills6
      I'm not 100% sure about this so am posting on here to see if anyone else has had the same issue. There seem to be creaks being made when I try to press the buttons of the Surface keyboard that are near the corners. Also, there appears to be a bubble of air underneath part of the cover, near the mouse pad. The creaks make the cover uncomfortable to use.
      Has anyone else experienced these? I'm going to try to get a replacement cover!
      Oli
    • ZipZapRap
      By ZipZapRap
      Hi all
      Having some trouble playing my music on my Surface. Everything is stored locally (on a MicroSD card). Up until yesterday, I could play all my tracks just fine.
      Last night I both reset the device (I was having issues with apps crashing) and entered a 3 month Xbox Music pass code. Now all of my music has been matched to the cloud (shown by the broadcast icon), and now, when I’m not connected to the internet, I can’t play ANY local tracks, except by going “open file”.
      At first, I got error message 0xc00d1126 when attempting to play. So I connected to the internet, redownloaded the Music app, and then tried again. This time I get error code 0xc1010091. But the same outcome – I can’t play local music automatically!!!
      This is REALLY annoying. Is there any way to force the app/device to play music locally first in the app, before streaming from the cloud??
      Uggh, this app alone has made my experience with Surface really bad. It’s been nothing but trouble. Any help would be most appreciated as right now, I just feel like getting rid of this thing.
      Thank you
      P.S. I have read the other thread on this issue, which hasn't helped.
