Cool Article Outlining Surface Gestures
scoobyx
I ran across this cool article that outlined most (if not all) of the primary gestures one would use on the touchscreen. I benefited from it and wanted to share it with you guys.
http://www.zdnet.com/microsoft-surface-rt-gesture-and-keyboard-shortcut-guide-7000006851/
I was going to say happy touching, but I figured that would be too easily misconstrued, so I will just say, "Enjoy!".
:rolleyes:
  • Like 2
    • Al_Borges
      By Al_Borges
      For sale , Microsoft Surface 3 tablet , 4 gigs memory, 128 gig storage
      good  used condition
      includes
      Urban Armor Gear scout case for surface 3
      Blue type cover for surface 3
      Surface 3 pen
      and charger/cable
      Asking $200 Plus actual shipping from Central Indiana, USA
      I love the tablet, but had to get an Ipad so I could facetime with my granddaughter !
    • andypdm
      By andypdm
      Hello everybody!
      I have a Surface Pro 4 i7 with 512GB which was very expensive! After a couple of months I have noticed that sometimes when I put it to sleep it won't wake up and I have to reset the whole thing. I love the device and use it a lot, and I twitted Microsoft and they contacted me and say that I have to replace it... I am OK with that but I live in UK and the service is from USA, they say they do not have my device and have to send me a refurbished one, on the other hand I can see the UK store has my model.
      My question is, what do you guys think of refurbished devices? Does it affect the performance? I am not too annoyed about the issue, I just do not put it to sleep anymore, but on the other hand it is annoying that a new and expensive item does not work properly. What would you guys do? I mostly use my Surface to draw with Illustrator and Photoshop...
      I would appreciate any short of advice and help!
      Thank you very much!
    • EON1488993291
      By EON1488993291
      Hello!
      I have a Surface RT (32 GB) and it only has 1.69 GB of space left on the HD. The thing is that I have almost nothing on it (just a few apps that I check and do NOT take a lot of space, and small files), so I don't know what is taking so much space. Does anyone knows where is all that memory going? I have not being able to find it (I have checked the size of the apps, delete the trash can, delete the internet history/cookies)...
      Also, I want to upgrade to Windows 8.1. These are the two ways that I have think of doing it, but I will like your opinion on which option is better (or if there is a better way):
      Plan 1: take the tablet to its original status (in PC settings > General > Remove everything and reinstall Windows), move the recovery files to a thumb drive (http://www.surfacegeeks.net/forums/index.php?/topic/192-surface-rt-how-to-free-up-4-gigabytes-of-storage-space-on-your-rt/), and do all updates to take it to Windows 8.1
      Plan 2: free some space by moving the recovery files to a thumb drive, make the upgrade to Windows 8.1, run a cleanup disk and defragment the drive
      Making a backup of the files in the tablet is easy b/c there is not much in it, but my main concerns for the process are: I am going to loose microsoft office? is it going to ask me for any key/license number (if I ever had one, I don't know where it is)? anything else that I am missing?
      Thanks!
      EON
    • IndyLux
      By IndyLux
      I recently learned that the Surface does not have a GPS radio in it. Not a huge deal, but might have been nice.
      My thought; why can't a tablet get GPS data from a smartphone? How cool would it be for our Surface to link to a Windows Phone (WiFi, blutooth, etc) to get GPS positioning data? That way, you don't need every technology in every device and they could share.
      I suppose why stop there, let's get tethering for LTE data as well (please!?!).
      Microsoft should conisider subsidising the carriers with hopes that we will use that connection to buy XBox content and stream it.
      Your thoughts?
    • IndyLux
      By IndyLux
      I'm experiencing intermittent function of my touch cover. Often, when I turn the surface on, the keyboard does not respond. I need to disconnect it and reconnect it, then it instantly works. This doesn't happen every time, but it's happened 5-6 times in the short time I've had it. Anyone else seeing this?
      I'm thinking either new connections that need to 'break in', drivers that need updating, or a faulty keyboard.
