Surface Storage 32 Vs 64Gb
Dave
I stated on episode 3 of the podcast, http://surfacegeeks.net/the-surface-geeks-podcast-episode-3.html , that I think I made a mistake getting the 32 Gb version. I have not loaded a whole lot, YET. I plan on installing a lot more this week and weekend. So far it has just been testing for me.
I'm not entirely sure of the return policy but I'm thinking of returning this one and getting a 64. What do you think?
For apps and docs 32GB would be fine. Wireless media streaming from my WHS has also been fine. So for those 32GB would be OK. But music, video and photos will fill things up fast if you want them on the Surface for offline access. The Metro multi-media apps are also happier if the files are local.
Written by someone with the 64GB Surface :)
Yes, so it really comes down to what you plan on using it? As osquest said, if you are a music/video person like me, the 32gb would not really fair you much. I suggest that before going out and buying one, really set down and think about how you are going to use it. This should gleam some light and help you make a decision.
Also, I would use SkyDrive ... it helps out alot. But then again, if you need it for "no service" use, then you will definitely have to use the local storage. I have mapped my documents library to only direct to my SkyDrive folder.
I have the 64GB and have not loaded a ton of apps, although I have installed a few, and I am down to 35GB free. Do the math. With a 32GB device I would already be getting closer to full than I like. Although I guess you could always add a SD card.
I've installed a few more apps today and still have 15.6 GB available.
Here is what I've installed on top of what is included.
SmartGlass
JetPack Joyride
Skydrive
Skype
MetroTwit
Evernote
Lastpass
Remote Desktop Metro
Kindle
Tweetro
I haven't bought my Surface yet and I'm reading this forum as much as possible before I do. You guys are blazing the trail so thanks for sharing your experiences.
It worries me to hear that nearly half of the 64GB is already used up if only a few apps have been installed. Is that really what's taking up the bulk of the used space? I'm using an Android 32GB device and even with a "ton" of apps installed, I have plenty of space available. In the past, Microsoft has had a reputation for building big, hungry software. Tell me that isn't the case with RT.
Music, videos, and pictures take up a lot of space. That is what is taking most of my space on mine.
Know just because it says 64gb SSD that doesn't mean the space you have when you get it is that much. It is actually less than that. Once you put the OS and all those files, plus it comes with Office 2013 on it. Those also take a lot of space.
Windows has always been known to be a memory heavy system.
I am using SkyDrive quite heavily on my Surface...seems to help.
    • Al_Borges
      By Al_Borges
      For sale , Microsoft Surface 3 tablet , 4 gigs memory, 128 gig storage
      good  used condition
      includes
      Urban Armor Gear scout case for surface 3
      Blue type cover for surface 3
      Surface 3 pen
      and charger/cable
      Asking $200 Plus actual shipping from Central Indiana, USA
      I love the tablet, but had to get an Ipad so I could facetime with my granddaughter !
    • EON1488993291
      By EON1488993291
      Hello!
      I have a Surface RT (32 GB) and it only has 1.69 GB of space left on the HD. The thing is that I have almost nothing on it (just a few apps that I check and do NOT take a lot of space, and small files), so I don't know what is taking so much space. Does anyone knows where is all that memory going? I have not being able to find it (I have checked the size of the apps, delete the trash can, delete the internet history/cookies)...
      Also, I want to upgrade to Windows 8.1. These are the two ways that I have think of doing it, but I will like your opinion on which option is better (or if there is a better way):
      Plan 1: take the tablet to its original status (in PC settings > General > Remove everything and reinstall Windows), move the recovery files to a thumb drive (http://www.surfacegeeks.net/forums/index.php?/topic/192-surface-rt-how-to-free-up-4-gigabytes-of-storage-space-on-your-rt/), and do all updates to take it to Windows 8.1
      Plan 2: free some space by moving the recovery files to a thumb drive, make the upgrade to Windows 8.1, run a cleanup disk and defragment the drive
      Making a backup of the files in the tablet is easy b/c there is not much in it, but my main concerns for the process are: I am going to loose microsoft office? is it going to ask me for any key/license number (if I ever had one, I don't know where it is)? anything else that I am missing?
      Thanks!
      EON
    • andypdm
      By andypdm
      Hello everybody!
      I have a Surface Pro 4 i7 with 512GB which was very expensive! After a couple of months I have noticed that sometimes when I put it to sleep it won't wake up and I have to reset the whole thing. I love the device and use it a lot, and I twitted Microsoft and they contacted me and say that I have to replace it... I am OK with that but I live in UK and the service is from USA, they say they do not have my device and have to send me a refurbished one, on the other hand I can see the UK store has my model.
      My question is, what do you guys think of refurbished devices? Does it affect the performance? I am not too annoyed about the issue, I just do not put it to sleep anymore, but on the other hand it is annoying that a new and expensive item does not work properly. What would you guys do? I mostly use my Surface to draw with Illustrator and Photoshop...
      I would appreciate any short of advice and help!
      Thank you very much!
    • G. WadeTech
      By G. WadeTech
      I am thinking about going to the event at the MOA on October 25th and I am interested to see if there are others that would be interested in meeting up at the store. Anyone want to go?
    • SurfaceNerd
      By SurfaceNerd
      Some are getting emails stating that their Surface RT tablets have already shipped. WPCentral wrote an article on this today. Although, I have received mine and my account still shows it as "in process". Anyone else get an email?
