Hdd case moding with 2.5 to 3.5 adapters
spacecake
A small idea how to add 5900 rpm disks. f48282f1229d9f8d40de61d98a42a614.jpg
4x 3tb on Dell sas ha
2x 1tb on HP internal raid
Boot from usb.
Will need to get a better solution for the cable management I know.. Need to find shorter and more flexible sas cables, too rigid to insert in the Dell sas hba.
ideas welcome
Update,
With some better cable management :
4x 3tb 3.5" mirrored vdev
4x 2tb 2.5" raidz
1x 250gb ssd (for vms)
8gb microsd (esx)
16 gb ram
E3-1270v2
Will test it with esx 6.5 + freenas.
As i am using dell sas in hba, will first go with esx 6.5 passthrue controller to freenas.
Ssd problem, ssd is connected to Sata port, as the 8 SAS2008 with 8 disks is passed to the vm..
P.s. Need to get another adapter for two 2.5" and shorter sas cable. Air flow is going to be slightly questionable
More about Bracket Adapter 2.5 to 3.5:
https://www.amazon.de/dp/B00GYZRGIE
https://www.amazon.co.uk/dp/B00GYZRGIE
Is that is just 22mm high, space available on the left side (where is the PSU) is around 23-24mm.  Plenty of space to open or close it.
For 5900rpm disks I don't believe the temperature is going to be a problem :)
Will order another or similar, to see how can I fit it on the right side of MS.
The worrying factor performance wise is the fact that the only free port where was able to connect the SSD is SATA1 (?) internal port :(
I did the initial setup last night of ESX and FreeNAS. Configured and imported the existing ZFS Pools. Not tested yet, will see how is it virtualized FreeNAS behaving.
*Good* thing is the consumption, measured idle is around 60W.
@Shonk Thanks. Need badly shorter SAS cables ..
