Reset 17 - HD Homerun signal problem comment
axoid
Hey Dave, just wanted to share,
I had a signal breakup problem with my old HD Homeruns after I cut the cord, but the problem wasn't the tuners. The issue was with one of the coax cables after the split. I was getting bad signal on one tuner, but excellent on the other. I found the problem by using an android app "HDhomerun Signal Meter" https://play.google.com/store/apps/details?id=com.zaren . After I replacing a couple of the coax cables the problem has been solved.
By the way, I've been very happy with Playstation Vue now after 7 weeks. Just wish the in-laws could figure out how to use the PS3. We're also using two Chromecasts to access PS Vue as well.
