P222 Problem
Richie-Kotzen
Hi,
i buy a P222 raid controller with 512Mb cache. When i put in my Microserver Gen8 it doesn't want to boot.
In early system initialization, arrive at 100% and reboot (boot loop).
I put the card in a desktop pc with windows 10 and i have upgrade firmware to the last one (8.0).
So the card is good, but why doesn't works in my server?
Thank you so much and sorry for my bad english!
Does it show up at all during the boot process? Can you in I'll under storage controllers to see if I'll can see it?
Sent from my LG-H910 using Tapatalk
Thank you schoondoggy!
No, it's remain in early system initialization, start from 0%, arrive at 100% and reboot continuously.
I think it's for an old firmware. I put the card on a desktop pc and upgrade firmware to the 8.0.
Microserver Gen8 have this config:
- INTEL XEON E3-1230v2 3.30GHz 8MB 69W
- 2x8GB Kingston ECC DDR3
This evening i try to put the card in another microserver gen8 base config (a G1610T Processor).
Do you have any ideas?
Did you check iLo for Storage devices?
No, i can't. In the iLo page, during the boot, i can't see any device connected.
In iLo4 are you looking at the storage devices area under system information? Page 173
https://www.google.com/url?sa=t&source=web&rct=j&url=http://www.hpe.com/support/ilo4_ug_en&ved=0ahUKEwiQs9_1tPTRAhVI6oMKHdarDU8QFggaMAA&usg=AFQjCNEIB7daFLdGowRvylY6yowoKEKKdA&sig2=tBK3dnXA9VWfMGSI-UsLUg
If you think it is a firmware issue you could just run the latest SPP on the server and it will update everything as long as it finds the P222.
At the beginning i think was a firmware problem, but it doesn't!
So, i put the card in an another microserver gen 8 ( G1610T and 8GB DDR3 ECC ) and the card works fine.
The only difference is ram and CPU.
It's a mistery... :-(
I try to move xeon cpu to the other microserver gen8 and now will not boot.
I think the problem is the xeon cpu. But why!?
After I remove the P222 card, in the Integrated Management Log i found this:
Uncorrectable Machine Check Exception (Board 0, Processor 1, APIC ID 0x00000001, Bank 0x00000003, Status 0xB2000000'00800400, Address 0x00000000'00000000, Misc 0x00000000'00000000)
I found in the forum this post:
http://homeservershow.com/forums/index.php?/topic/5895-potential-cpu-upgrade-options-for-microserver-g8/page-2#entry75119
Edited by Richie-Kotzen
The PCIe lanes are on the CPU. Your XEON may have bad contacts or bad lanes.
I think the xeon is good. Is the same problem of the user capvid86.
Tomorrow I try to put a NIC card in the pci-e and I think it's run correctly.
