Power Management in Bios
paulkhor
Hi there,
What's the recommended setting for the HP Power Regulator in the Bios?  I have an E3-1260L (Turbo Disabled in Bios) in my Gen8 MS, 12gb ram, AHCI Mode.
So far, I've tried 2 of the following settings with the following results.
OS Control Mode     -          CPU will downclock to 1.6ghz when idle, 2.4ghz when on load.
HP Dynamic Power Savings Mode         -          CPU will stay at 2.2ghz at idle, 2.4ghz when on load.
Am I doing anything wrong? Thanks
Paul
Edited by paulkhor
well thats how 99.9% of pc's on the planet do it so yes
That's a big claim ;)
Changed it and the CPU speed is definitely lower than what it was before - so I'll stick with the OS controlled.
My gen8 is a fileserver, a downloading machine and a Plex server, so I really don't need it on high CPU speeds. In fact, I might use the power options under Windows to reduce the maximum processor state.
Edited by tangcla
