Power pins on Mobo Dell T20 and additional pins for adding a fan
yoojioh
Hi,
I just added H310 on my T20, but it's generating a lot of heat and worried if the heatsink is not enough to cool it down.
I see people recommend adding 40mm fan on it, most of which require 3 pins on motherboard,
but I don't see any other additional power pin connectors for the additional fan on H310.
Does T20 motherboard just not have additional power pins for extra fans, or am I not looking for it correctly?
- still noob
If I remember correctly there are no extra fan connections on the mother board. You can add two wire fans off powered one of the drive power connections.
Thanks, I'm just so hardware noob to understand what it means. Do you mean I can use some of the pins from 6-pin HDD ODD POWER?
