how do I boot from my SSD using optical port for sata
dreamworkz
I have this setup already with the SATA controller set to Legacy but for obvious reasons I want to use AHCI, how can I convert over without loosing any data?
I believe I need to plug in a USB stick and then copy the boot partition to that? The problem is, the way server 2016 has installed is that there is no seperate boot drive, it is part of the main partition where windows is installed.
