USB 3.0 Ports Not Performing At 3.0 Speeds
serioussam1215
My main desktop computer's USB 3.0 speeds are fine but when I copy things over to my hard drive on my server, the speeds drop to sometimes 5mbps. It's atrocious! Is this a driver issue? Getting very frustrated here.
I have tried several USB 3.0 devices. I have used Corsair, Kingston, and Sandisk as well as a 3.0 HDD Toaster on my main PC with no hiccups 100+mbps. Switch to server, dips to 15mbps as I stated.
Are your devices write speeds upto the job alot of usb sticks have far slower write speeds compared to read speeds
If you post the model and size i will tell you the max write speed of the devices
you may well be writing to a device with 120 megabytes read and 20 megabytes write
Over smb you will get an initial burst at wire speed for around 2 gigabytes undil the recieve buffer is full on the server
then it will drop to the speed of the device being written to
Edited by Shonk
Is there software or software/hardware that can test all USB ports (including 3.1)?
I only know of MUTT which I don't think works for 3.1
