abpostelnicu Posted October 5, 2016 Share Posted October 5, 2016 Hello, I've just bought a HP P212 raid controller and put it in my MS Gen8. I think it has a very old firmware - 3.0 mart Array P212 in Slot 1 Bus Interface: PCI Slot: 1 Serial Number: PACCPID103200H8 Cache Serial Number: PACCQ9SYXM71 RAID 6 (ADG) Status: Disabled Controller Status: OK Hardware Revision: C Firmware Version: 3.00 Wait for Cache Room: Disabled Surface Analysis Inconsistency Notification: Disabled Post Prompt Timeout: 0 secs Cache Board Present: True Cache Status: Not Configured Drive Write Cache: Disabled Total Cache Size: 256 MB Total Cache Memory Available: 144 MB No-Battery Write Cache: Disabled Battery/Capacitor Count: 0 SATA NCQ Supported: True My question is how i can upgrade the firmware and from where can i get the latest one. I'm running on an Debian OS that boots up from ODD bay with software RAID 5 - 4 disks Link to comment Share on other sites More sharing options...
abpostelnicu Posted October 5, 2016 Author Share Posted October 5, 2016 I'll respond myself to this question, a complete guide with the latest firmware can be found here: http://h20564.www2.hpe.com/hpsc/swd/public/detail?swItemId=MTX_55b304486f544f148de6c5cc6e#tab1 Link to comment Share on other sites More sharing options...
schoondoggy Posted October 5, 2016 Share Posted October 5, 2016 You can also update it using the latest SPP. Link to comment Share on other sites More sharing options...
mrpenguin Posted October 5, 2016 Share Posted October 5, 2016 If I read that correctly-- the Drive Write Cache does not work with a P212 and the gen8 (and, therefore, hardware raid 5 is not supported--hence why you are using software raid 5?) Is that right? (I had a similar question on the P212 and gen8 recently--not meaning to thread hijack) Hello, I've just bought a HP P212 raid controller and put it in my MS Gen8. I think it has a very old firmware - 3.0 mart Array P212 in Slot 1 Bus Interface: PCI Slot: 1 Serial Number: PACCPID103200H8 Cache Serial Number: PACCQ9SYXM71 RAID 6 (ADG) Status: Disabled Controller Status: OK Hardware Revision: C Firmware Version: 3.00 Wait for Cache Room: Disabled Surface Analysis Inconsistency Notification: Disabled Post Prompt Timeout: 0 secs Cache Board Present: True Cache Status: Not Configured Drive Write Cache: Disabled Total Cache Size: 256 MB Total Cache Memory Available: 144 MB No-Battery Write Cache: Disabled Battery/Capacitor Count: 0 SATA NCQ Supported: True My question is how i can upgrade the firmware and from where can i get the latest one. I'm running on an Debian OS that boots up from ODD bay with software RAID 5 - 4 disks Link to comment Share on other sites More sharing options...
abpostelnicu Posted October 5, 2016 Author Share Posted October 5, 2016 If I read that correctly-- the Drive Write Cache does not work with a P212 and the gen8 (and, therefore, hardware raid 5 is not supported--hence why you are using software raid 5?) Is that right? (I had a similar question on the P212 and gen8 recently--not meaning to thread hijack) Where did you read this? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
mrpenguin Posted October 5, 2016 Share Posted October 5, 2016 (edited) It was mostly a guess from what you had written; I don't know very much about servers, hardware, or maintenance-- So it is really just a logical assumption on my part. As they say, a little knowledge is dangerous :-P This was from your status post: (which made me assume the DWC doesn't function) Cache Board Present: True Cache Status: Not Configured Drive Write Cache: Disabled Total Cache Size: 256 MB Total Cache Memory Available: 144 MB No-Battery Write Cache: Disabled I don't know very much about servers, hardware, or maintenance-- So it is really just a logical assumption on my part. As they say, a little knowledge is dangerous :-P Edited October 5, 2016 by mrpenguin Link to comment Share on other sites More sharing options...
abpostelnicu Posted October 5, 2016 Author Share Posted October 5, 2016 it says disabled since no array is configured 1 Link to comment Share on other sites More sharing options...
mrpenguin Posted October 5, 2016 Share Posted October 5, 2016 Gotcha! on the other thread, (which you probably have already seen), Schoondoggy has CONFIRMED that hardware raid 5 will work with the cache module. I will now be looking to order one of those and see! (http://homeservershow.com/forums/index.php?/topic/10938-interesting-smart-array-p212-may-be-supported-in-the-gen8-still-testing/#entry121981) Link to comment Share on other sites More sharing options...
abpostelnicu Posted October 5, 2016 Author Share Posted October 5, 2016 Yep great news!! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
