HP GEN8 problem with 1TB Hard disk
mammifero
Good Morning
a little help
i have HP Microserver GEN8
i have bought 2 Western Digital HD
WD10EFRX Hard Disk Desktop for NAS, Intellipower, SATA 6 GB/s, 64 MB Cache, 3.5 ", 1 TB, Red
on the pdf file of the quick spec of the microserver is written that is possible to use hard drive of 1 tb
but my system didn't recognize the hard drive when i run the raid utility during the boot
i'm stupid :)  or there's something that i don't know ?
best regards
Matteo
Currently, when you go into the B120i setup, you do not see any drives?
I would check to be sure the drives are slid all the way into the bays. I would also check the cable from the back-plane to be sure it is plugged into the motherboard firmly.
You may want to check the drives in another computer to be sure they power up properly.
