Universal Voltage Datacenter Smart PDU
dalem
I was thinking it would be great for a cable modem or a router.  How annoying would it be if you were traveling.  You try to vpn into your network and it is not connecting because it is locked up or something.  This could ping the modem or router and reset if it doesn't respond.
Be better if I can tell it to test and state that if it cannot ping three times in a row (each separated by 5 min) then restart, those of us with shitty connections the inability to ping externally happens when downloading things occasionaly
That is a good point.  I don't know how configurable it is.  I had an ISDN line back in the mid 90's.  I had to setup a crontab on one of my Debian boxes to ping every couple minutes to keep the connection up.
