Open Mesh with Untangle
mattd390
I have a question for anyone running Open Mesh with Untangle.  Did you perform any steps, beyond simple port forwarding, to allow OM to phone home?  Can you list any ports you forwarded too, please?  Thank you greatly for any feedback!
I did not have to open any ports for OM, It worked fine behind Untangle.
Can it still get updates?
Yes, My MR1750 was working fine behind Untangle. Are you having a problem with it? Log into Cloudtrax and click on Access Points on the left hand side and look at the last check in, If its checking in you should be fine.
ItGeeks is correct. I actually allow each of my MR1750 units unfiltered web access to phone home. Not sure that's even necessary. They're flawless.
