LSI 2308 HBA to Intel P4000M 3.5" backplane cable?
Altecice
Hi there,
I'm putting together a new server build and I have a query about the type of cable I require.
So the plan is to buy an Lsi Sas 9207-8I (flash it to 2308 IT to run FreeNAS passthrough on ESXi):
As you can see they use this type of connector (I cant remember its name).
Due to my case choice I will be using a P4000M Intel FUP8X35HSDK 8x3.5 Hot-Swap Drive Cage Kit New:
Am I right in thinking I just need to grab two cables and put 1 for 1 in each port of the HBA?
If so what cable do I require?
Edited by Altecice
Looks like SFF-8087 connectors on each end. Check the manuals to be sure, but it look like you need two SFF-8087 to SFF-8087 cables.
  • Like 2
Ahh.  I can only find the manual for the LSI and it does indeed list the connector as SFF8087. I think it's safe to assume that the backplane on the hotswap bay is also the same. Thanks for the response :)
