Microserver Gen8 Noise issue in RAID mode
sungrief
Hi Guys!
Been reading the forums for quite a while now, but so far cant seem to find a description of the issue I am seeing in my MS Gen8.
I basically have the fan issue (Fan running at ~50-70%) when I use the B120i in RAID0 mode.
My config is: G2020T with 16G RAM
250 GB SSD 2.5" in Bay1
3 TB WD Green in Bay2
1 TB WD Black in Bay3
640 GB WD Blue in Bay4
Now every disk is its own RAID0 array on the controller.
When I run this in AHCI the fan issue does not occur... but then I have issues in ESXI with timeouts for the disks in AHCI so forced to use B120i...
System ROM J06 07/16/2015
System ROM Date 07/16/2015
Backup System ROM J06 06/06/2014
iLO Firmware Version 2.30 Aug 19 2015
Firmware on the B120i is 5.00
Software on the Host:
char-hpcru    HP CRU Kernel Module    6.0.6.14-1OEM.600.0.0.2159203
char-hpilo    hpilo: HP Channel Interface Driver    600.9.0.2.8-1OEM.600.0.0.2159203
hp-ams    HP Agentless Management Service    600.10.3.0-15.2494585
hp-conrep    HP Configuration Utility Conrep for ESXi 6.0    6.0.0.1-0.0.13.2159203
hp-esxi-fc-enablement    HP ESXi Fiber Channel Enablement Package for ESXi 6.0.0    600.2.4.6-2494585
hp-smx-provider    HP Insight Management WBEM Providers for ESXi    600.03.09.00.15-2768847
hpbootcfg    HP ProLiant Boot Configuration Utility for ESXi    6.0.0.02-01.00.11.2159203
hpnmi    HP NMI Sourcing module for ESX 6.0    600.2.3.14-2159203
hponcfg    HP ProLiant Lights-Out Configuration Utility for ESXi    6.0.0.04-00.13.17.2159203
hpssacli    HP Smart Storage Administrator CLI for ESXi    2.30.6.0-6.0.0.2159203
hptestevent    HP ProLiant Test Event Utility for ESXi    6.0.0.01-00.00.8.2159203
scsi-hpdsa    HP Dynamic Smart Array Driver    5.5.0.46-1OEM.550.0.0.1331820
scsi-hpsa    HP Smart Array SCSI Driver    6.0.0.114-1OEM.600.0.0.2494585
scsi-hpvsa    HP Dynamic Smart Array Driver    5.5.0.100-1OEM.550.0.0.1331820
tg3    Driver for HP Ethernet 1Gb 2-port 332i Adapter    3.137l.v60.1
Any ideas? Perhaps more info?
Thanks in advance!
Edited by sungrief
I will need to do some searching. Someone had a similar issues and found that certain drives were causing the problem. If it is a fully functioning system it may be hard to try, but I would try pulling the 640gb drive. What brand and model is the SSD?
Removing the WD640 did the trick... its and old laptop HDD and hoped to use it for some storage:))) Guess not the best idea... The SSD is Samsung 840 EVO.
After removing the WD640, I have 9-18% fan speed! Will keep monitoring and update if issue comes back
Thanks schoondoggy! :)
