Looking for basic setup guide for my ML10v2
felt
I am not expert but just set up mine and it was frustrating coming from a N54L microserver.
  The boot sequence is long and itself reboots at least once with some beeps during the process, so you need to wait it out.  If the ram is compatible and seated correctly, you should see the counter progress past 10%. Mine goes up to at least 70% before the screen changes, but the boot sequence takes a long time, probably minutes.
 I would boot with a monitor attached and watch the whole time, maybe with a cup of tea/coffee/beer.  It will show you the options for bios (F9 I think) and there are some other options as well like boot sequence if all is well.
If you do not see these and multiple other screens then you have a problem.  I could only suggest videoing the boot seqeunce nad uploading to youtube for more experienced people to look at.
If all is well you need to change the boot sequence and maybe go into the storage section of the bios to change the disks to ahci mode.  The bios is relatively normal once inside.
I installed an os from usb, but it said to create a dos bootable usb stick which I did with rufus from memory, then installed the files to the usb, and it installed fine.  Not too hard but I certainly didn't get it right the first time.  Once you get your head around it, it kind of makes sense.
