Home firewall options?
Similar Content
By JROrtiz
By Jason
Have been running a Windows DHCP server on home WSE12R2 box for quite some time behind my Sophos UTM firewall. Also allowed me to seamlessly run Windows Deployment Services at home. WDS just worked.
But if I needed to make a particular LAN IP address exception on the firewall, I had to 1.) create a Windows DHCP server reservations AND 2.) create a network definition for that IP on the Sophos UTM box. 2 steps. Not very efficient; was sure I was doing something incorrectly...
Tried to migrate to Sophos UTM running the DHCP Server, but now WDS doesn't work. LAN devices can no longer PXE boot. Seems possible. Many guides. None have proven especially successful.
Is it possible to run a Windows DHCP server and have Sophos UTM import DHCP reservations instead of maintaining 2 unique entries for each IP reservation (one in Windows DHCP, another on Sophos UTM box)?
What is best practice?
By donschmidt
Good morning. I've just purchased a home still under construction and plan to have CAT6 installed throughout the living areas. I'm hoping that someone can advise me as to the specific quality/specs of cable that I should use.
Thanks and Happy New Year.
By Joe_Miner
I've been looking at the Intel Compute Stick BOXSTK1AW32SC and was wondering if anyone here has experience with that and if the Intel AC 7265 built into it is backwardly compatible with older N and A,B wifi?
By heavy21
I want to optimize the performance and security of my home network of servers, PCs, laptops printers, smartphones, TVs, etc. Current network appliances include layer 2 and 3 switches (Cisco small business) and Linksys router. I’m looking to replace the Linksys with a security (pfSense) router appliance (w/OpenVPN). I will also be adding security cameras and a NVR to the network.
The gigabit network is straightforward in structure with all Ethernet connections hanging off the24 port switch connected to the cable modem and router except a cascaded 8 port switch in a room to provide 4 Ethernet connections in a room with only one data port. Wireless connections presently come off the Linksys but will eventually come off the to-be-purchased security/router appliance with a wireless card. I don’t see more than 100 devices in total for the whole network. No VLANS and no sub-netting. All hardware supports IPv6.
Hardware line up is:
Dual Zeon server w/RAID 10 of 24 TB of storage, 64GB memory
Cisco managed switches layer 2 and 3
HPEX495 server
Workstations, Desktops, Laptops, Tablets, iPads
Printers
Software line up is:
Windows Server Essentials 2012 R2, single domain controller, storage and file server duties
Windows 10 Pro all non-server Intel computing devices
PLEX server for streaming audio and video to display units
Office 365
From what I’ve read so far, it appears that I need to incorporate an IP addressing scheme for clients and servers on the network. It would also appear that I need to implement VLANS and/or sub-netting to protect access to certain files and security footage, provide guest networking with future consideration for electronic door locks and some sort of server based media distribution to various display devices,
What are best practices on assigning client and server devices to IP ranges, fixed or dynamic IP addresses? Do I need to assign clients or servers to IP ranges? What are the considerations in establishing sub-nets over VLANS or vice versa? I’m pretty sure I want to restrict access to cameras and their security footage and personal files on my workstation.
Thanks for any resources and advice provided.
