​ HP Microserver gen 8 fan speed - all you need to know
Jochem
With my inlet ambient in the range of 20-23C (not accurate; my ambient temperature is for sure cooler than this) AHCI mode, SSD in bay 0 and 3x1TB WDs in bay 1-3 my fanspeed was in the range of 10-12%.
fans.thumb.jpg.004f469919150c20de7531dfbd083a6c.jpg5963981371b25_sensordata.jpg.686dc557d5d34f75d7acf29254945082.jpg
I disconnected the inlet temperature sensor as suggested above by Shonk (creating a reading of -1C) and now my fanspeed is 6%
5963990a329f6_temperatures(sensordisconnected).jpg.d8f3d48e818c8a422867af9c2d867ec4.jpg5963990287612_fan(sensordisconnected).thumb.jpg.e7833e28a762824c82cb670842042a8a.jpg
I would prefer that I didn't have to disconnect this sensor. The main reason I did it is that I felt it is poorly calibrated. If it showed  a more accurate reading then I would leave it attached and I guess my fan would be somewhere in between 6% and 10%.
Anyway this shows that 6% is possible with AHCI
Finally an answer shame I have a really high tdp cpu in mine now in the loft otherwise I would have left disconnected the sensor and left it in the front room good to know though
  • 4 weeks later...
Today I replaced 2.5" HDD in the 5th slot with an SSD. Fan speed went down from 60% to 6%.
I tried first two (identical) hard drives sourced from Lenovo laptops and both always showed hdd temp as 43C. With the SSD temp shows as 35C but the fan stays quiet. I would have rather used it in a laptop but this silence is a worthy sacrifice.
  • 9 months later...
Reviving an old thread here but did anyone have any luck
Ive had mine running with an SSD in the ODD bay and 2x 2tb sata in bays 3 and 4 (only 3gbps drives) with vmware 6.7 hp version and fans were always under 15%
i just added two 256gb sata6 SSD drives to bays 1 and 2 and configured in RAID0 and now my fan speed once booted into esxi (hp custom image with hp agents) is at 70%
have i missed something here?
Just guessing, but some SSD do not have temp sensing, if iLO does not see a temp reading it speeds up the fans.
Please post here the readings of temperature sensors from iLO.
  • 1 year later...
I did use this forum to get news and information about the HP Gen8 microserver since a couple of years.
Today I came accross the following thread which might be an interesting solution for all of you who are still facing the fan issue (like me). I am using the Gen8 with the B120i in AHCI mode where iLo is unable to read HD max.
Silence of the fans: Preliminary success with muffling iLO's control of my DL380p G8 fans
  • 1 month later...
Doesn't look like too many folks are discussing this anymore (I've been watching it for many years), but thought I'd just mention that after I just updated iLO from 2.4 to 2.7 (a little late to the party...) my fan speed went from ~19% to ~10% with no other hardware/software changes (4 WD Reds in AHCI). Just thought I'd mention in case anybody else found it interesting that HP still seems to be adjusting that stuff...heh.
  • 6 months later...
Nice one! Mine seems to have gone in the other direction, although I have just started configuring again. Time for some testing!
  • 2 months later...
I have latest BIOS and iLO (Health Diagnostic: OK)
AHCI mode using 3 HDD for storage (all has temp attr. 194) and 1 SSD for OS (temp attr. 190) -> No HD Max sensor.
CPU is Xeon 1220 v2 (tdp 65w), Ram 2x8gb.
Power Regulator set to OS Control Mode.
Inlet Ambient sensor disconnected.
Ambient is 23-26C
Fan speed: 26-40%
What I'm doing wrong?
Edited by PpenoO
