adih2001 Posted May 18, 2016 Share Posted May 18, 2016 (edited) Hello! I bought a ML10v2 yesterday but i cant find the product number! I have located the serial number since is on top but i can't find the product number. Can anyone point me where could it be??? (I have tryed HP S/N but that dosen't work) Note: I need to add a warranty so i can download SPP Edited May 18, 2016 by adih2001 Link to comment Share on other sites More sharing options...
GotNoTime Posted May 18, 2016 Share Posted May 18, 2016 Hello! I bought a ML10v2 yesterday but i cant find the product number! I have located the serial number since is on top but i can't find the product number. Can anyone point me where could it be??? (I have tryed HP S/N but that dosen't work)I think the label is on the bottom of the chassis. If not, check http://www8.hp.com/h20195/v2/GetPDF.aspx/c04567802.pdf Link to comment Share on other sites More sharing options...
adih2001 Posted May 18, 2016 Author Share Posted May 18, 2016 I think the label is on the bottom of the chassis. If not, check http://www8.hp.com/h20195/v2/GetPDF.aspx/c04567802.pdf I have checked that area but its not there... and the manual doesn't seem to talk about the product number. Link to comment Share on other sites More sharing options...
bigjezza Posted May 18, 2016 Share Posted May 18, 2016 (edited) if you run msinfo32 on the server (windows) it will list it under system SKU or try the warranty check tool https://h20566.www2.hpe.com/hpsc/wc/public/find Edited May 18, 2016 by bigjezza Link to comment Share on other sites More sharing options...
jmwills Posted May 18, 2016 Share Posted May 18, 2016 Belarc Advisor should give you that as well. Link to comment Share on other sites More sharing options...
adih2001 Posted May 18, 2016 Author Share Posted May 18, 2016 if you run msinfo32 on the server (windows) it will list it under system SKU or try the warranty check tool https://h20566.www2.hpe.com/hpsc/wc/public/find The problem is i need to setup the raid and i cant access the raid without the SPP and i have no os on it since i havend setup the SPP because i need the model number to register it to the warranty 1 Link to comment Share on other sites More sharing options...
schoondoggy Posted May 18, 2016 Share Posted May 18, 2016 SPP is for updating BIOS and Firmware. You access the raid controller during the boot cycle. If you do not see the raid controller load at boot, you may need to enter setup and enable the raid controller. Link to comment Share on other sites More sharing options...
bigjezza Posted May 18, 2016 Share Posted May 18, 2016 That link should do it click on the identifier on the results page. Link to comment Share on other sites More sharing options...
adih2001 Posted May 18, 2016 Author Share Posted May 18, 2016 (edited) SPP is for updating BIOS and Firmware. You access the raid controller during the boot cycle. If you do not see the raid controller load at boot, you may need to enter setup and enable the raid controller.Well in the bios the smart hp raid controller thing is selected but when i press f5 on boot it wont show the setup screen for it. What was the problem is that i installed an debian linux on the hdd but i the bios didn't boot on the hdd even when i forced to do so. Weirdly when it boots it says at the raid controller 0 logical volumes and it tells me to press f5 to set it up and i press it says it will open but it still boots to NIC Edited May 18, 2016 by adih2001 Link to comment Share on other sites More sharing options...
schoondoggy Posted May 18, 2016 Share Posted May 18, 2016 Look at your boot priority. Be sure B120i is before NIC. Link to comment Share on other sites More sharing options...
