N54L and DL380p Gen8 drive cage
maddog
Hi all.
Thought there might be someone in here that can answer my question.
I already have a HP N54L, and recently i've received a DL380p Gen8 server, and i want to use the "new" DL380 instead.
My question is, can i use the drive cage including the splitter cable from the N54L (which as far as i can read, is a SFF-8087 connector) in the DL380, using the internal connector (by disconnecting the internal SAS port 2 and reconnect the N54L cage here).
I can't find detailed info on the internal connector on the DL380, so not sure if it is SFF-8087.
Also, will this mess up with the DL380 fan config and alerts when i disconnect the SAS port 2.
Thanks in advance guys ;-)
/Mads
