SAN Storage - HP GEN8 Microserver ? NOOBIE NEEDS HELP
Allyal123
Dear all .
I have been a long time lurker of these forums and have taken incredible amounts of help from others in my early days of home labbing wiht my GEN8's . I have been overwhelmed by the amount of usefull content and great discussions that have been held here !
I am in the process of designing a high speed SAN storage array for home lab use until i can figure a production build for one of our datacentres in the UK .
At present i have loaded my gen8 up with a cheap Qlogiq 2460 card and using a sneaky exploit im running freenas to host the fibre channel .
Right now my SAN storage for my homelab has set me back 25 quid for the two FC  cards and a 1m cable . * winning *
But .
I have to build a pre production proof of concept  so a hacked copy of freenas isnt going to fly
I have spotted for good prices the following HP san enclosures ( HP M6412A ) and need to know if this will require another storage controlling server or weather i can just LC-LC fibre cable this straight into the GEN8 micro's FC card and hope Xenserver picks up the LUN
I apologise for what is likely considered a peculiar and poor quality first post . I dont usually post in forums but from the wealth of knowledge ive gained from lurking these boards im hoping someone amongst the ranks can help with my latest homelab / Proof of concept endeavour .
Welcome!
The M6412A is a drive enclosure to add disks to a HPE EVA storage array. It may run as a JBOD, but not as a SAN.
How many servers do you intend to connect to the production SAN at work?
Is there a requirement to use Fibre Channel?
Do you have a Fibre Channel switch?
Home lab SAN setup can be done in many ways. Using iSCSI instead of FC is a cost effective way to build your storage network. Use separate Ethernet NICs and a Ethernet switch to create the storage network. For your SAN storage array, you could load FreeNAS on a server/PC and set it up as iSCSI target mode. Some of the small NAS devices from Synology, QNAP, Thecus and Seagate can also be set up as a iSCSI target.
How much disk space do you need to test your POC?
Stepping back, what are you trying to achieve at work?
