Noisy power supply fan (PSU) on ML10v2
acubino
Hi.
I just install my new ML10v2 and upgrade all firmware. I read some post about the noisy, and I see have some firmware issues solved more than 1 year ago.
I thinks my system as noisy. I open it, and manual stop (yes i know that is wrong) the system fan, iLo say is 9% only. Noise don't stop. I check the PSU and check that noise are from here, i think this is the 2 wire 8 cm fan into the PSU.
Any with this problem?. I don't know is this fan is pwm controlled by iLo or all times are 100%.
Suggestion?
I just change the default fan for a amazon bouth Artic Cooling F8.
The noise of the artic cooling is very low, but the air flow is lowest to the original. I don't know if i will have in the future problems with this, if have a will buy a new silent power supply and made the 10 custom pin.
This is the link for Amazon USA fan.
http://www.amazon.com/ARCTIC-F8-Standard-Noise-Case/dp/B002QVFN7G/ref=sr_1_1?s=pc&ie=UTF8&qid=1460037060&sr=1-1&keywords=ARCTIC+F8
For installation, yellow cable unconnected.
In Amazon Spain, only 3.50€.
The PSU fan is always on and can't be adjusted from software. If you think it is excessively noisy then you need to get HP to swap out the PSU.
