Hard drive sizes /options
keymaster
Hi
My buddy has a standard gen 8 with 4gig ram and 4 x 6tb WD reds, O/S is Xpenology but it seems on 2 of the drives are seen by Xpenology, is hardware limited to 12tb or Xpenology?
What are his options please?
Many thanks
K
Hi
Thank you for reply, I think Basic raid without protection
K
P.S. he has joined forum now and can respond himself
Edited by keymaster
Cheers Keymaster ;-)
thanx for the quick response Schoon
Volume 1
Raid Type :Basic without protection
file system :EXT4
Volume 2
Raid type: Synology hybrid raid without protection
file system: EXT4
Edited by Dava2k7
Thank you managed to sort the problem
For reference (so that if other users run into the same issue), how did you sort/solve the problem?
well its abit of a long story but keymaster put xpeneology on my gen 8 Id bought a dodgy drive in past and it crashed the system so the software that worked before wouldn't work I replaced drive and moved things about and sorted the problem but never wiped OS so some of my programs still don't work properly but once I started downloading more things I didn't have another drive so I bought a drive and tried to use a usb 3 caddy to send things over which wouldn't seem to work so I thought it was down to hard drive capacity but never put drive in actual server since yesterday the software I was using has been getting updated and things seems to be repairing themselves overtime but the drive is now in and fully initialised many thanks
