Need a serial port on 2020T
znelbok
I am having some trouble with a touch screen that is connected to the G8 2020T.  Elo recommend using a serial port instead of a USB adapter.
So instead of putting in an add-on card, I am hoping there is a header on the motherboard that will give me a serial port.
Can anyone confirm if there is a serial port available on the motherboard.
Mick
No serial port header available. USB to serial or a PCIe serial port card are your only options.
The serial port detected is the virtual serial port option for iLO. It isn't an actual physical serial port.
