Grapfics driver problem
Viper922
Hi all. I have a HP Proliant ML 310e gen8 v2 and I was forced to put on it a windows 7 ultimate x64. I searched a lot and I can't find a driver for the graphics card, even with hp support assistant(it doesn't find anything). For Newtork Card I found a driver and works fine. Can somebody help me? Thanks a lot!
Welcome to the forums!
Looks like the graphics card is a NVIDIA Quadro K2000 Adapter
Have you tried this driver? http://h20564.www2.hp.com/hpsc/swd/public/detail?swItemId=wk_145914_1&swEnvOid=4059
This is another one I found however I have NEVER downloaded any drivers from this site so be careful and make a restore point before installing any of these drivers
http://drivers.softpedia.com/get/GRAPHICS-BOARD/NVIDIA/NVIDIA-Quadro-K2000-Graphics-Driver-918132601.shtml
There is also a great free program that I use for updating my drivers called Driver Booster by IObit, They have both a paid and free version I use the free version. http://www.iobit.com/en/driver-booster.php
The only thing I will tell you is like many well known company's that provide free software they have one or two programs set by default to install with it so read and uncheck the install
'Advanced System Care' unless you want to try that also. Other then that Driver Booster is a big time saver and has never hosed any of my systems over the years.
Edit: I just found this driver on NVIDIA site, I would try the drive from HP & NVIDA as well as IObit before trying the softpedia site because as I said I never tried drivers from there.
http://www.nvidia.com/download/driverResults.aspx/86814/en-us
Hope this info helps...
Edited by itGeeks
The onboard graphics for the HP ML310e V2 is a Matrox G200eH. It is built into the iLo chipset. I would try the Windows Server 2008 driver:
http://h20564.www2.hpe.com/hpsc/swd/public/detail?sp4ts.oid=5379533&swItemId=MTX_678f14caa28a43c0a10625d59a&swEnvOid=4064
If that does not work you can go to Matrox and get a Windows 7 driver.
Sorry to the OP I looked up the drivers on the HP website and I missed the 2nd graphics driver listed here http://h20564.www2.hpe.com/hpsc/swd/public/readIndex?sp4ts.oid=5379533&swLangOid=8&swEnvOid=4064
Glad you got it sorted out :)
I come again with a problem. I thank that the driver is ok because the writing, images and video looks more clear, but I see some problems. Some web pages does not fit well the screen, and the screen page of Windows looks like this:
http://postimg.org/image/6dp4fe91t/
Is it not the good driver or should I install other drivers? I installed 3 drivers, one for network, one for graphic and one for usb. The usb driver I installed it because driver booster told me that I haven't.
I tried to install other g200eH driver like this but id doesn't work, it told me: No Matrox Hardware Detected. Same as with all drivers for NVIDIA Quadro, No Hardware Detected.
Thank you!
One thing that I observed is that if I want to run in compatibility mode, option for Windows 7 does not exist,  even if is the driver that worked or is the other one. On my laptop where I have a windows 7 x86 if I look at compatibility mode, Windows 7 appears there, but on my HP Proliant ML310e gen8 v2 win7 ultimate x64 does not appear.
Take a look here and see if you can find a better drive http://www.matrox.com/graphics/en/support/drivers/previous/display/
You can also open up Windows device manager and right click display adapter click properties click driver click update driver and see if Windows finds a better driver.
I have the driver version 1.3.1.0 from 4/11/2012. If I search with Windows it says that is up to date, but I wouldn't trust it. I searched on that site but I don't know exactly what to look for.
